OBD0 to OBD1: Car won't start
Old Aug 4, 2005 | 07:44 PM
brnyrdcmndo's Avatar
Default OBD0 to OBD1: Car won't start
I'm getting spark and fuel pressure but I'm not sure if I am getting an injector pulse. I converted to OBD1 injectors and ECU, do I still need the resister box? Could this be my problem.
Old Aug 6, 2005 | 01:49 AM
Honda Sport's Avatar
which injectors are you using? saturated injectors will not use an injector pack. peak and hold will use an injector pack.
Old Aug 6, 2005 | 06:28 AM
Default Re: (Honda Sport)
I'm using saturated injectors.
Old Aug 8, 2005 | 05:58 AM
Default Re: (brnyrdcmndo)
When I spray carb cleaner in the intake the car fires up. I think this confirms that fuel is getting to the rail but the injectors are not firing. Any idea why this would happen. All wiring has been converted to OBD1. I am using OBD1 (saturated) injectors and an OBD1 ECU. I am still using the OBD0 injector clips but I modified the injectors to accept the OBD0 clips. I was told this would be fine, as the only difference was the two tabs that needed to be shaved down on the injectors. Could I have received wrong information regarding this? Please help, I need to get this car running. Thanks!
Old Aug 8, 2005 | 08:12 AM
Jaker's Avatar
Who's OBD0 to OBD1 adapter did you buy, and how did you wire the OBD1 distributor?
Old Aug 8, 2005 | 09:02 AM
what ecu dizzy and ecu combo you using? you can only use obd0 ecu with obd0 dizzy and obd1/2 ecu with obd1/2 dizzy.
Old Aug 8, 2005 | 04:23 PM
Default Re: (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Who's OBD0 to OBD1 adapter did you buy, and how did you wire the OBD1 distributor?</TD></TR></TABLE>
I'm not using an OBD0 to OBD1 adapter. The harness was custome wired by Indomotor.
Old Aug 8, 2005 | 04:44 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brnyrdcmndo &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not using an OBD0 to OBD1 adapter. The harness was custome wired by Indomotor.</TD></TR></TABLE>
Are you getting any codes? Have you contacted the "Custom" builder?
Old Aug 8, 2005 | 05:03 PM
you should just contact them and see what's wrong.
what dizzy and ecu combo you using? you can only use obd0 ecu with obd0 dizzy and obd1/2 ecu with obd1/2 dizzy.
Old Aug 8, 2005 | 06:49 PM
I'm using an OBD1 P28 ECU and a P30 OBD1 dizzy. I have contacted the custom builder, but he has yet to get back to me.
Old Aug 8, 2005 | 07:58 PM
It's throwing code 16...fuel injectors. No surprise there!
Old Aug 8, 2005 | 08:45 PM
I reset the ecu and the car started right up. However, it is still throwing code 16. Currently (just until I get it tuned) it is running a P28 with a B20 Vtec high compression tune. It is tuned for 550cc injectors. Could this cause it to throw a code 16?
Old Aug 9, 2005 | 10:45 AM
bump for afternoon experts!
Old Aug 9, 2005 | 09:24 PM
curioso's Avatar
i had the same problem, are u using an obd1 distributor or an obd0 , my problem was the distributor i did the obd1 conversion using p28 and the harness from jdmshit and wire everything right and it would just crank and wouldt start, then i use my friends obd1 distributor and it started right up with out any codes or anything, get an obd1 distributor if ur not using one yet hope this helps u man
KevinEF7
Oct 21, 2012 05:46 PM
CRX44
Aug 31, 2009 11:13 PM
si 1
Mar 10, 2006 05:23 PM
KevronsEG
Nov 7, 2002 09:25 AM
