obd1 and obd0 injectors different?
Old Oct 16, 2012 | 01:01 AM
KevinEF7's Avatar
Default obd1 and obd0 injectors different?
hey guys, basically I am piecing my turbo kit together and need to buy injectors, something to sustain about 400whp on a daily driver. I have a currently obd0 rhd crx. But MAY convert to obd1.
I will be boosting a d16a6(d16z6 intake and fuel rail) which comes factory with a resistor box.
Im confused if I can buy an injector and have it work with both setups? Rather I stay obd0 or go obd1?
is there a specific detail I should be looking for when purchasing??
thanks alot
Old Oct 16, 2012 | 04:34 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: obd1 and obd0 injectors different?
The difference is peak and hold versus saturated injectors.
This is EASILY searchable, and really doesn't belong in the Forced Induction forum to begin with.
The injector requirements aren't decided by the ECU but rather the injector impedance.
So basically you need to pick an ECU OBD, then choose injectors to support your WHP goals, and finially either keep the resistor box installed or remove it to satisfy the injectors. Here, this will put a little shake in your boots:
http://www.hondata.com/techlowohminjectors.html
Just do it right boy!
Old Oct 16, 2012 | 10:25 AM
KevinEF7's Avatar
Sorry I wasnt sure what forum to put it in, that read is very technical I will have to sit down and read it a few times after work.
What are the "standard" type of injectors for turbo OBD1 hondas in the 350-400whp range, or if I stuck with OBD0
Old Oct 18, 2012 | 01:51 AM
rice a roni's Avatar
precision makes high and low impendence injectors: http://www.precisionturbo.net/air-fu...t-Injectors/40
or if you're staying obd0, I'd pick up some lancer evolution 550cc injectors and just keep the resistor box on. Some say that the 450cc injectors can hold 300hp.
Old Oct 18, 2012 | 11:02 PM
KevinEF7's Avatar
Im going for 350+ whp so Im not even sure the 550's would be good enough, I dont want to run such crazy high duty cycles
Old Oct 19, 2012 | 08:32 AM
4drEF's Avatar
Keyboard Humorist
Think you are going to want around a 700cc injector.
I would go with the low impedance with a resistor box at that size of injector.
I know they are available in both types, but the non-resistor box type tend to be a little laggy. It's more noticeable when you need to run the bigger injector hard.
Old Oct 21, 2012 | 05:46 PM
KevinEF7's Avatar
And I can keep my factory resistor box after switching to obd1 and it will work with whatever "resistor box style" biggere injectors I get?
br8crumb
Jun 1, 2014 10:00 AM
CRX44
Aug 31, 2009 11:13 PM
atarigamer01
13
May 20, 2008 09:23 AM
si 1
Mar 10, 2006 05:23 PM
brnyrdcmndo
Aug 9, 2005 09:24 PM
