OBD0 car with OBD1 motor What 310cc injectors to get?
i have a 91 crx si with sohc vtec and you can run OBD0 injectors with the resister box or run OBD1 injectors with somw wiring. i have yet to put the motor in. so what 310cc injectors do i get? is there even a diffrence? thanks guys
Re: OBD0 car with OBD1 motor What 310cc injectors to get? (CIV616)
you do not need to re wire the car to run obd1 injectors, you have to change the injector clips.You can get accel 23 pound injectors that are peak and hold cheap thru summit or jegs. Jason
Re: OBD0 car with OBD1 motor What 310cc injectors to get? (littlebluecrx)
so what should i do guys i can get 310cc but dont wnat to get wrong ones
What ECU are you using? Did you use the OBD0 or OBD1 wiring harness? OBD0 and OBD1 injector clips have the same pattern, BTW. They will fit RC's and DSM's just fine. The question is whether or not your need a resistor pack and that is determined by your wiring/ECU.
Sonny
hondacivic90zc
03-06-2007 06:02 PM
