Need help, need pictures of Hasport mounts
I need pictures or instructions on installing Hasport's EGH2 mount kit for an H22A into a 92 civic hatch. More specifically, I'm having difficulty with the passenger side mount and bracket. Any info your have would be appreciated. Pictures of installation or finished installation would be Awesome.
I know what the mount looks like.. this will be my second h22eg hatchling..
I just need to know how to remove the bracket from the frame rail.
The install was done professionally last time. I paid too much and want to do it myself.
The instructions say either die grind it or drill the spot welds... Which method is preferred?
I would rather drill the welds.... I don't know.
Pictures if anyone has please!!
Thanks
Thanks
i used a prybar and a large hammer... then i used chisles and a hammer to clean it up some. that was on my swap... I used a grinder on my friends swap it was easier in some cases and harder in others... Its no science just get it off of there
drilling is the easiest i think. drill out the stop welds, u can see them, they are the dimples in the bracket, but don't drill all the way through the frame rail. after that wack it with a really big hammer and pry it off with pry bar, and grind it smooth with a grinder.
we usually like to spray paint that area where the bracket used to be a similar color to the car color so it doesn't look to obvious that its been removed aswell. we also do that when we weld in 5speed brackets after removing the auto brackets cuz the brackets come black from the dealer.
kulo
May 17, 2013 04:32 PM
Hatch_Kid
13
Dec 31, 2012 06:22 AM
Sir_Phobos
11
Apr 10, 2003 09:13 PM
