Only starts sometimes. (need opinions)
Old Aug 3, 2005 | 03:37 PM
DeadVet's Avatar
Default Only starts sometimes. (need opinions)
Well lately my 92 civic has been pissing me off. I go out and the car starts right up, If i shut the car off and try to start it again it wont start, just cranks. While it wont start I AM getting spark and fuel. If I let it sit for 10-15 minutes or so it will fire right up.
If I start it up and shut it off so it wont start and then push start it it fires right up no matter what every time. I have replaced the main relay and ignition switch but nothing fixes it.....When I push start it the only thing it is bypassing is the starter and maybe the ignition but the motor cranks just doesnt start. What do you guys think?
Old Aug 3, 2005 | 07:41 PM
BenzTek134's Avatar
Default Re: Only starts sometimes. (1TurboHatch)
check your fuel pump relay. check your ignition igniter, check your starter, check for proper ground at battery and at starter.
Old Aug 4, 2005 | 02:54 AM
DeadVet's Avatar
Default Re: Only starts sometimes. (BenzTek134)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BenzTek134 &raquo;</TD></TR><TR><TD CLASS="quote">check your fuel pump relay. check your ignition igniter, check your starter, check for proper ground at battery and at starter.
The fuel pump relay is inside the main relay and i swapped it out and it didnt change. The starter is fine because its cranking....All grounds are good. The only thing i havent swapped out is the ignitor but i have spark so i dont see it being that.
But then again the car SHOULD start all the time because i have spark and fuel.
The only thing i can think of is that the car is not getting ENOUGH spark to start it sometimes.....Its getting spark but maybe its not enough.
Old Aug 4, 2005 | 01:06 PM
alleyezonme's Avatar
maybe check the gap on the plugs?
Old Aug 4, 2005 | 01:36 PM
DeadVet's Avatar
Default Re: Only starts sometimes. (alleyezonme)
I called and spec with a master tech at honda....he said to replace the ignitor. He said when the coil goes then the ignitor isnt far behind it. He also said the ignitor's job is to boost the spark on start up that would explain why i can push start the car because the ignitor isnt being used.
Old Aug 4, 2005 | 06:05 PM
dcp48's Avatar
do u have any check engine lights? i think the same thing happens to me because of my iac valve.. its the only check engine light i have.. my car will drive fine until im at a red light then the car will dive down till it chokes out.. when i try to crank it wont... just turn over.... and over... i let it sit for about 10-15 mins...itll start right up... i dunno man.. when u fix ur prob pm me and tell me how u did it.. i wanna know...
Old Aug 5, 2005 | 04:36 PM
DeadVet's Avatar
Default Re: (95ex-t)
no check engine lights.....I swapped out the ignitor today and it didnt change.....I am ******* lost and have swapped just about everything and still cant fix it.....Any other opinions or advice?
Old Aug 5, 2005 | 05:31 PM
5spdfrk's Avatar
Did you replace the old main relay with a new one?
If not, check the solder joints on the main relay.
Here's a how-to:
http://www.marklamond.co.uk/ho...y.htm
Old Aug 6, 2005 | 01:11 PM
DeadVet's Avatar
Default Re: (5spdfrk)
Well i looked into it somemore today and i have fuel pressure but my injectors arent firing.....What tells the injectors to fire.....Where should i go from here?
Old Aug 6, 2005 | 06:08 PM
Takumi Fujiwara's Avatar
Default Re: (1TurboHatch)
Things I would check in this order because I've been there:
1) PGM-FI relay
2) Ignitor/Coil
3) Distributor itself.
If you have a friend that can lend this stuff to you... that's the best case scenario
Old Aug 7, 2005 | 05:58 AM
DeadVet's Avatar
Default Re: (Takumi Fujiwara)
the ignitor and coil have both been swapped out....The main relay has been swapped out. If i start the car and then i turn it off but dont turn the key to the "lock" position it will start up every time providing i dont turn the key to the "lock" position when i shut it off.....
Old Aug 7, 2005 | 10:30 AM
DeadVet's Avatar
Ok well the car can not be started anymore as it could in my last post by not putting it in the "lock" position. It is back to its "start when it wants to" mode....Thing is it runs great when it does start....I have about had it with this piece of **** car.....
Old Aug 7, 2005 | 04:39 PM
DeadVet's Avatar
Anyone have any suggestions?
Old Aug 8, 2005 | 06:23 PM
DeadVet's Avatar
Someone has to know something.
Old Aug 8, 2005 | 07:01 PM
civicstar's Avatar
well i had problems with my motor like that, it happened when my battery was losed and move around and the grounds were messed up, i grounded the motor with a circle earth grounding kit and it hasnt shut off like that anymore. but it could be sumthing else
Old Aug 9, 2005 | 10:22 AM
boostmywankle's Avatar
Default Re: Only starts sometimes. (civicstar)
mike, have u checked the ignitor...my gsr did that when the ignitier was on its way out....it pissed me off...then after a week or so the ignitor took a ****...
Old Aug 9, 2005 | 01:33 PM
DeadVet's Avatar
Default Re: Only starts sometimes. (96teggyls)
yep, replaced the ignitor with no luck.
Old Aug 9, 2005 | 02:25 PM
**** thats shitty
Old Aug 9, 2005 | 02:49 PM
getzy3's Avatar
my car does the excact same thing (94 dx hatch) and my 92 four door did the same thing. it only does it when it is really hot out though. If i let it set for about 5 mins it fires right up and sometimes it starts then a couple seconds later it just dies no matter if you give it gas or not.
Old Aug 10, 2005 | 02:25 PM
getzy3's Avatar
Default Re: Only starts sometimes. (getzy3)
anyone??
Old Aug 10, 2005 | 07:50 PM
DeadVet's Avatar
Well i fixed my problem....It happened to be the a bug in the tune.....sounds like your problem is the main relay.
vplukas101
Jan 25, 2013 04:09 AM
91rexhf
10
Dec 27, 2008 05:06 PM
91greenbeast
19
Sep 30, 2008 09:09 AM
Xumarius
Nov 1, 2004 08:07 AM
PUSHER
Jun 21, 2004 11:21 AM
