what can cause the speedometer to not work?
92 dx hatch, vx/si cluster forget which (car is at home can't check). is it plug n play? the speedometer doesn't work, milage doesn't go up when driving, needle does not move. what are the possibilities and which one most likely the problem.
I'd first replace the speed sensor in the engine bay. Then I'd have someone check all the wires are connected properly to their homes, and are grounded well. I've done all this, and I've been told the only solution is to replace the damn thing with one from a junkyard. This is a common problem with eg civics, so i hear.
Jvl41291
Oct 8, 2018 02:34 PM
ONEhaque
Nov 4, 2008 06:31 PM
ithinkitsjdm
13
Feb 23, 2005 06:17 AM
