how much can i boost my sohc?
Old Feb 20, 2002 | 07:20 AM
jmad08's Avatar
New User
Default how much can i boost my sohc?
right now i have a 00' sohc w/ a custom T25 kit boosting @ 5psi. i was wondering how much can my stock internals take? will a INLINE PRO head gasket help me to boost higher? right now for my fuel setup i have stock injectors, Bosche hp inline pump, and a Vortech 12:1 fmu. what will i have to do to be able to increase the boost a little bit more and still be reliable?
Old Feb 20, 2002 | 07:50 AM
Hybrid's Avatar
Default Re: how much can i boost my sohc? (jmad08)
I know a guy with a D15B running 8-10 psi. but remember it has to be done wisely, and you have to know how to tune. you just don't put a boost controller on there and up it to where you want it. Definetly get your self an EGT and A/F gauge to monitor your engine.
Oh yeah he is doing this with out a standalone, only an FMU, and fuel pump. Ran it all last year no prob at 8psi no prob. Although towards the end of the summer he broke a ring land (can't remember which cylinder) when he pushed the boost too much. Good thing for spare parts hey.
This year he is hoping for 12psi daily with no intercooler either, but he is running an alcohol injection setup.
Good luck with it.
Old Feb 20, 2002 | 08:34 AM
blind's Avatar
New User
Default Re: how much can i boost my sohc? (Hybrid)
i am planning to run on low compression pistons with intercooler on a t3 turbine. How much boost can my sohc take???
Old Feb 20, 2002 | 08:42 AM
D-Man's Avatar
if you get rid of the stock injectors,fmu and ecu and go with a programmable ECU like a AEM,Accel,Haltech etc and like 450-550cc injectors,with that,a stock D16 will hold up to 14psi(mine has for almost 40,000 miles on a 62,000 mile engine i purchased from a junkyard) ,forget the inline pro head gasket,waste of money cause the compression ratio is fine and the stock honda gasket will hold,whats gonna fail first before a headgasket are the pencil thin rods equipped in a D16,theyll snap if u push it over 14psi
Old Feb 20, 2002 | 08:54 AM
TurboSedan's Avatar
New User
Default Re: how much can i boost my sohc? (D-Man)
I agree with D-Man, boosting on the SOHC is fine as long as you plan it out and use a standalone. Then you can really pump some power out of it!!
Old Feb 20, 2002 | 10:49 AM
jmad08's Avatar
New User
Default Re: how much can i boost my sohc? (97CivicFerio)
how much would a Haltech cost? is it plug and plag system? would i still need that if i decide to leave it at 6-7psi?
Old Feb 20, 2002 | 11:39 AM
Pritos's Avatar
New User
Default I boosted 17psi....
.. for 2 seconds on a d15b7. i dont think I need to tell you what happened though.
7psi max on stock internals w/o standalone is somewhat reliable.
Old Feb 20, 2002 | 12:14 PM
RoaringTurtle's Avatar
New User
Default Re: I boosted 17psi.... (Pritos)
ive been running 9psi daily on mine for about 6 months
been running fine
i plan on getting a standalone unit, probably the aem ems one and some new injectors
i want to try to get 12's
i might take the risk of pushing it to 14 psi but then again i have a greddy kit and im not sure if it can take that much abuse all the time
so maybe just 12 psi daily and at the track up it to 14
Old Feb 21, 2002 | 06:02 PM
jmad08's Avatar
New User
Default Re: I boosted 17psi.... (RoaringTurtle)
Old Feb 22, 2002 | 11:43 AM
jmad08's Avatar
New User
Default Re: I boosted 17psi.... (jmad08)
any other turbo sohc's wanna say anything???????
Old Feb 22, 2002 | 04:10 PM
jmad08's Avatar
New User
Old Feb 22, 2002 | 05:03 PM
turbocoupe's Avatar
Definitley get an A/F and EGT gauge. If you can tune right you should be able to run up to 1 bar with little worries.
acuragtr
Jul 4, 2005 09:15 AM
1tyme
Apr 28, 2004 03:57 PM
BoostedD15B7
Aug 8, 2002 12:26 PM
99civicdx
Jun 27, 2002 02:27 PM
dohcvtec717
Apr 7, 2002 03:23 PM
