EG Headlight allignment
Old Jul 31, 2005 | 03:34 PM
Kaneo's Avatar
Default EG Headlight allignment
Did a search no luck, wondering if anyone knew how to adjust the allignment on the headlights. Thanks in advance.
Old Jul 31, 2005 | 04:07 PM
alleyezonme's Avatar
Default Re: EG Headlight allignment (Kaneo)
there are two screws on the back of the headlight that you can turn to adjust them. they turn a whole lot. if you tighten them all the way it will point out and down and think. one for the one direction one for the other (obviously!).
good luck
travis
Old Jul 31, 2005 | 09:02 PM
Kaneo's Avatar
Default Re: EG Headlight allignment (alleyezonme)
thanks for the help man, ill give it a try tomorrow.
Old Jul 31, 2005 | 09:05 PM
fms1day's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme &raquo;</TD></TR><TR><TD CLASS="quote">there are two screws on the back of the headlight that you can turn to adjust them. they turn a whole lot. if you tighten them all the way it will point out and down and think. one for the one direction one for the other (obviously!).
good luck
travis</TD></TR></TABLE>
couldn't have said it any better... i believe OEM are 10mm bolts and 'some' aftermarket/replacement are '+' screws
Old Aug 1, 2005 | 09:46 AM
Kaneo's Avatar
Default Re: EG Headlight allignment (fms1day)
I actually have jdm eg6 headlights, would that make a difference?
Old Aug 1, 2005 | 09:51 AM
92HatchB16's Avatar
No, they are exactly the same size as the stock honda ones...I have them and was able to adjust them very easily.
Old Aug 1, 2005 | 09:53 AM
JDM-EJ1's Avatar
Does anyone know how to do this with JDM EG6 lights?
Old Aug 1, 2005 | 11:20 AM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kaneo &raquo;</TD></TR><TR><TD CLASS="quote">Did a search no luck</TD></TR></TABLE>
k now your either lying or suck at searching cuz i made a thread a while ago asking the same question and since u suck at searching here it is
https://honda-tech.com/zerothread?id=1249154
Old Aug 1, 2005 | 11:23 AM
JDM-EJ1's Avatar
Default Re: EG Headlight allignment (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">k now your either lying or suck at searching cuz i made a thread a while ago asking the same question and since u suck at searching here it is
https://honda-tech.com/zerothread?id=1249154</TD></TR></TABLE>
Wow, there is no need to be an asshat about things. No wonder you're 95%.
In either case, to align the headlamp you just need to play with the ***** on the back of the light to adjust it where you want it.
Old Aug 1, 2005 | 11:49 AM
Kyles ej1's Avatar
Default Re: EG Headlight allignment (JDM-EJ1)
i wasnt being an "asshat" about it dickface, all i said was he probably lied about searching just like everyone does when thats the 1st thing they say in their post.
and im at 95% cuz some of the mods dont like hot girls and i had one in my avatar
04TYPEsaggin
May 12, 2008 04:11 PM
jxhxb
Dec 3, 2007 11:15 PM
aych2h
11
Jan 17, 2007 11:47 AM
HondaJack
10
Nov 9, 2006 03:16 PM
mikehawkBUiLT
11
May 3, 2004 11:43 AM
