EG Headlight allignment
Re: EG Headlight allignment (Kaneo)
there are two screws on the back of the headlight that you can turn to adjust them. they turn a whole lot. if you tighten them all the way it will point out and down and think. one for the one direction one for the other (obviously!).
good luck
travis
good luck
travis
1 Post
Re: EG Headlight allignment (alleyezonme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme »</TD></TR><TR><TD CLASS="quote">there are two screws on the back of the headlight that you can turn to adjust them. they turn a whole lot. if you tighten them all the way it will point out and down and think. one for the one direction one for the other (obviously!).
good luck
travis</TD></TR></TABLE>
couldn't have said it any better... i believe OEM are 10mm bolts and 'some' aftermarket/replacement are '+' screws
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kaneo »</TD></TR><TR><TD CLASS="quote">Did a search no luck</TD></TR></TABLE>
k now your either lying or suck at searching cuz i made a thread a while ago asking the same question and since u suck at searching here it is
https://honda-tech.com/zerothread?id=1249154
Imperious: Mod of Valor
Re: EG Headlight allignment (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">k now your either lying or suck at searching cuz i made a thread a while ago asking the same question and since u suck at searching here it is
https://honda-tech.com/zerothread?id=1249154</TD></TR></TABLE>
Wow, there is no need to be an asshat about things. No wonder you're 95%.
In either case, to align the headlamp you just need to play with the ***** on the back of the light to adjust it where you want it.
Re: EG Headlight allignment (JDM-EJ1)
i wasnt being an "asshat" about it dickface, all i said was he probably lied about searching just like everyone does when thats the 1st thing they say in their post.
and im at 95% cuz some of the mods dont like hot girls and i had one in my avatar
jxhxb
12-03-2007 11:15 PM
mikehawkBUiLT
11
05-03-2004 11:43 AM
