Headlight questions for an EG
Does anyone know if there is a headlight for an eg that uses the 9006/9005 headlight set up?
Thanks,
Jack
Thanks,
Jack
Re: (deryck324)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deryck324 »</TD></TR><TR><TD CLASS="quote">jb weld and silicone </TD></TR></TABLE>
Silicone completely destroys the plasti-chrome that the headlight reflectors are made of... if you use silicone to reseal your headlights or use it so that fumes in any way get inside the housing be prepared for TERRIBLE lighting...
I couldn't figure out why my headlights were so dim.... until I read somewhere about the silicone killing the relector material... after I swapped them out sure enough... ALL of the nice shiney chrome was dull and cracked/peeled.
Def. don't use silicone.
Re: (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz »</TD></TR><TR><TD CLASS="quote">
Def. don't use silicone.</TD></TR></TABLE>
it was a joke i say just get hids
Re: Headlight questions for an EG (HondaJack)
From what i've read, there is nothing you can do to improve the eg headlights - other than an HID Retrofit...
NOT just a HID Kit.. a Retrofit with projectors and a CLEAR lenses headlights.
You can buy or retro the TYC One piece, or you can also try and retro ebay projectors
imo: ebay look really crappy...
I say go and buy the Clear Lens TYC replacements, and see if the output is better with those
if not you've done the first step to retrofitting.
Darth ModerVader
Re: Headlight questions for an EG (bpr0422)
If you wanted to stay with halogen, you could also try to source some E-code headlamps from an EDM Civic. Combined with a set of high-performance halogen bulbs such as Philips Vision Plus, they should provide a decent improvement over the stock DOT units.
what you talking about you can just get h4 style hids and they look fine or you can just get the one peice headlight /corner light that allready set up for hids
mikehawkBUiLT
11
05-03-2004 11:43 AM
