3000 RPM idle 5-sp swap searched!
Old Jul 30, 2005 | 02:52 PM
HCivExoo's Avatar
Default 3000 RPM idle 5-sp swap searched!
Converted pin B6 to pin B23 and wired yel/blk to yel/blk and blk/blu to blk/blu. I did not remove the orange wire B15 from the harness. but i still have a 3000 RPM idle ??? do i just need to remove the orange wire or is this a bad iacv???
It sometimes surges from 2500 to 1000 like it was just disconnected from the plug.
I also wired the Park and neutral wires to the clutch interlock switch and i have to push the clutch in to start it but i still can't get the key out without disconnecting the battery. ??? i read that i may have to connect wires 10 and 11 on the auto gear selector harness aswell??? any ideas
Old Jul 30, 2005 | 03:57 PM
HCivExoo's Avatar
Default Re: 3000 RPM idle 5-sp swap searched! (HCivExoo)
alright removing the orange wire B16 from the plug did not do anything, just incase i had put he wires in the wrong place onm the plug i switched the wires in the plug and that did nothing as well. I haven't gotten any ecu codes yet and i have driven probably 20 or 30 mile since getting started earlier today. Is it possible htat i jsut have a bad IACV ???
i have searched and haven't seen anything like this. I have done everyhting that i have read over and over again to do with this swap.
any help here guys. please thanks
Old Jul 30, 2005 | 04:32 PM
HCivExoo's Avatar
well guys i am through for the night will check in the morning or tomarrow sometime maybe somebody will beable to tell me what the problem is?
Old Jul 30, 2005 | 04:33 PM
JDM-97CX's Avatar
Unplug the IACV while the car is idling, if the problem goes away then you have a bad IACV.
Old Aug 4, 2005 | 01:23 PM
HCivExoo's Avatar
Default Re: 3000 RPM idle 5-sp swap searched! (JDM-97CX)
Put a new IACV on and it still persists. I put a Integra GSR throttle body could have been off an LS i don't know for sure? could air be coming in through somewhere on the valve allowing it to idle too high ??
Civicex0
Jan 26, 2018 04:00 AM
VTcivicHB
Nov 11, 2005 05:08 PM
b18c5dc2
Sep 10, 2003 05:16 AM
xSpooNxEkx
Jul 13, 2003 02:16 PM
CivicEx95
Apr 26, 2002 05:24 PM
