spark plug wire question
Old Sep 9, 2003 | 08:10 AM
b18c5dc2's Avatar
Default spark plug wire question
I recently put a set of MSD super conductor 8.5 wires on my R. They seem to work fine, I can tell the difference. The only problem I have is that the wire comes of the plug after high rpm use. I don't understand why they are doing this, I mean the wire "snaps" on the plug really tight. Any suggestions as to why the wire's are coming off the plugs will be greatly appreciated. Also what RPM does a 2001 Type R idle at fully warm with the A/C off. Mine has 36,000 miles and I swear the RPM's dropped at idle. It idle's anywhere between 720 and 960 - it fluctuates constantly at idle. I just don't remember the tach dropping down to 720 before. If any of these topics have been posted before, I'm sorry. I tried doing the search and could'nt find anything. thanks for any help on this.
Old Sep 9, 2003 | 08:53 AM
vtec.dc2's Avatar
Default Re: spark plug wire question (b18c5dc2)
i suggest to use stock oem sumitomo plug wires - not one problem with these.
did you use dielectric grease?
for idle.. when you say it fluctuates constantly.. like it will jump from 700-1000 withing 2-3 seconds? or at times its 700 and other times its 1000? if so, then 700 should be with no load.. and 1000 when radiator fans come on.. although it should be 800 (+/-50) with no load and 1050 with a/c or fans on (+/-50), and 850(+/-50) if EVAP system is purging the canister. - according to helms manual.
Old Sep 9, 2003 | 04:42 PM
K20DC2R's Avatar
Default Re: spark plug wire question (vtec.dc2)
check if your plugs are on tight 18 ftlb and for the low idle clean the throttlebody and then check what happends. if still low try a valve adjustment.!
Old Sep 9, 2003 | 04:50 PM
Fac3Man's Avatar
First throw those wires away, if they are anything like the Magna****** dont bother using them. I have a set of Magnacores and they pop out just like your MSDs, get some stock wires.
As for the idling, what vtec.dc2 said.
Old Sep 9, 2003 | 05:02 PM
K20DC2R's Avatar
Default Re: spark plug wire question (Fac3Man)
i have a set of magnacores and they work just fine.! hmm could be just a set of bad wires?
Old Sep 10, 2003 | 05:13 AM
b18c5dc2's Avatar
Default Re: spark plug wire question (VtecWhore)
Now that I think of it, I had the valves adjusted by the local acura dealer about 2 weeks ago. I guess I'll take it back and have them check it out and see if the idle RPM is correct or not. Thanks for the reminder.
Old Sep 10, 2003 | 05:16 AM
b18c5dc2's Avatar
No, I did not use the grease. I took your advise and actually used the dielectric grease and the wires seem to stay put now, I took the motor to about 8200 numerous times on the interstate and like I said - the wires are now staying on. Thanks for the info.
rsanders21
Oct 25, 2010 05:19 PM
dfoxengr
Oct 26, 2008 04:02 PM
Punker1234
13
Aug 6, 2005 06:07 PM
FLCivic
Oct 26, 2002 09:57 AM
hondafrk
Sep 15, 2002 09:52 AM
