head gasket write up
Old Jul 30, 2005 | 12:38 AM
Ls91sI's Avatar
Default head gasket write up
wondering if anybody had a old write up, or diy to replace a head gasket on a b18a. trying to avoid taking the entire timing belt out if possible. any help is appreciated
Old Jul 30, 2005 | 04:03 AM
non-VTEC's Avatar
Default Re: head gasket write up (Ls91sI)
that would not be possible........if you dont know how to re-install the timing belt then you should not be doing a headgasket......pay someone else to do it for you.
Old Jul 31, 2005 | 06:21 AM
sik96teg's Avatar
Default Re: head gasket write up (non-VTEC)
um u can do it wit out pullin the crank pulley and timing belt i do them all the time
Old Jul 31, 2005 | 07:45 AM
Strikerrr's Avatar
yea I just did mine. without pulling the crank pulley out. All you have to do is slide the timing belt off, after you ajust it to TDC. Make sure you mark it though using white-out, nail polish. ETC just to make your life easier.
Old Aug 2, 2005 | 05:25 PM
Ls91sI's Avatar
thanks for the help.....i still want to know if theres a write up or somethiin out there to help me do this
Old Aug 2, 2005 | 07:10 PM
PrettyLude's Avatar
the best write up would be the helms manual
Old Aug 2, 2005 | 09:44 PM
krazie1's Avatar
BANNED
Default Re: (PrettyLude)
yeah it would or u can try c-speedracing. com
they got how to up the ying yang and good ones at that
not just crap
Old Aug 3, 2005 | 01:41 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (krazie1)
Personally, I find it to be a LARGE pain in the *** to get the cam gears and everything lined up to TDC unless you take the timing belt off and reinstall it in the right order. Otherwise its always just a hair off.. could be just my stupid *** though.
Old Aug 4, 2005 | 04:13 AM
sik96teg's Avatar
Default Re: (JDM_Ej)
i think its jus u j/k it took me a while to get it down now i can change a timing belt in about 15-20 mins compared to the 3 hours it took me the first time only like an hour to do a head gasket. If u want i can photo copy the helms write up for doing a head gasket at work since i lub free loudin off the air force.
93delsold16z6
Aug 9, 2012 06:33 AM
niceguyjp2183
May 9, 2006 02:51 PM
JONBLAZE55555
Nov 18, 2003 06:37 PM
gavhowe
May 7, 2003 08:45 AM
Piston_Honda
12
Feb 21, 2002 06:18 AM
