Egine Bogging
Old Jul 29, 2005 | 05:02 PM
One2NV408's Avatar
Default Egine Bogging
Hi i actually been a HT member for years now but my comp crashed and yeah. So heres my problem, i got the same swap a D15B for my 93 del sol. This engine was from Japan. After i swapped the CEL came on and it was a code 10 IAT sensor, so i replaced that. It idles fine but when i rev it up the engine boggs between 2-3K rpm. I changed the o2 sensor, got new spark plugs, spark plug wires, and distributor but it still boggs between 2-3 rpm when i rev it hard. But i am able to rev it slowly and its fine. When i took it out to test drive it just bogs and barely move anywhere.
Please help me fellow HT members, i am stressed to the max.
Old Jul 29, 2005 | 05:50 PM
One2NV408's Avatar
Default Re: Egine Bogging (da93soul)
Please help out fellow HT members, I have been pouring money into this car and its the first car i've bought with my own money so for those who paid for their own rides you know there are sentimental values to it.
Old Jul 29, 2005 | 06:08 PM
sicky's Avatar
grammer nawzi
Have you checked the fuel pressure? Side note: if you comp crashed that would not delete your HT account. . . don't be ashamed of being a noob.
Old Jul 29, 2005 | 06:17 PM
One2NV408's Avatar
okay on the realz i had an aol account but we shut that down to get yahoo DSL and i lost my password on that accound so i had to start a new one. Theres fuel going through but could it be the fuel filter?
Old Jul 29, 2005 | 07:07 PM
One2NV408's Avatar
Just did a fuel pressure test and it is in normal range. I need help guys parents are pressuring me to sell it.
ANY ONE?
Modified by da93soul at 8:51 PM 7/29/2005
Old Jul 29, 2005 | 07:51 PM
One2NV408's Avatar
ANY ONE?
Old Jul 30, 2005 | 08:03 AM
One2NV408's Avatar
Today is a new day and i need as much help as i can get this POS has taken 3 months of my time since i have work as well. PLEASE FELLOW HT MEMBERS help another brother out.
Old Jul 30, 2005 | 04:00 PM
One2NV408's Avatar
Someone told me it could be that my ECU is on limp or safe mode that prevents the engine from over reving or it could be ignition problems. Can someone verify this?
Old Jul 30, 2005 | 04:21 PM
JDM-97CX's Avatar
Throttle Posistion Sensor (TPS)
No way in hell you are in limp mode, because then you would have a rev limiter at 3k.
Old Jul 30, 2005 | 05:40 PM
One2NV408's Avatar
Default Re: Egine Bogging (JDM-97CX)
Could my CEL be off even if the TPS is broken? Because my CEL is not on. Only time it was on was when it threw a code 10 IAT sensor and i changed that.
Thanks JDM-97CX, are there other opinions out there?
Old Jul 31, 2005 | 09:02 AM
One2NV408's Avatar
is there any way to take off my TPS because theres no visible nut thats holds it. Theres like a washer and a bolt and something inbetween. Can some one help me out?
Old Jul 31, 2005 | 09:08 AM
siregcivic's Avatar
hey check to make shure that you dont have the tps and the map sensor mixed up ive done it before and it idles fine but wont rev for ****
Old Jul 31, 2005 | 09:13 AM
One2NV408's Avatar
Default Re: (siregcivic)
the map sensor is where it should be because it couldn't reach the TPS and vice versa, Thanks for looking out.
I fould out how to remove it after searching, but would it need to be recalibrated even if the TPS was never adjusted or moved before. Because when i did my swap i had to remove the whole intake manifold including the TB. SO just wondering if i should take the time to dremel it and check the volts and recalibrate it.
Modified by da93soul at 12:07 PM 7/31/2005
Old Jul 31, 2005 | 03:46 PM
siregcivic's Avatar
hey also check to make shure the cam isnt advanced or retarted a tooth or 2
that would make a difference too man gl tho
Old Jul 31, 2005 | 03:56 PM
CivicHP's Avatar
i recently did a d15 swap in my 93 coupe well it sounded like my engine was bogging after it was warmed up i opened my hood but cold not see any weird sound or engine movement so i put my hand behind the muffler exit and felt a drop of pressure it was like puffing went to honda did an oil change and no more problem. maybe it not your case.
Raul Cipriano
Apr 1, 2022 10:51 PM
patrick_yi_82
Sep 9, 2013 06:10 AM
92BlackSi
14
Apr 8, 2005 11:00 AM
Timmay
Feb 4, 2004 02:34 PM
BoOsTeD_eK
Oct 28, 2002 05:18 PM
