Help me with my LS problem.
Old Oct 27, 2002 | 03:52 PM
BoOsTeD_eK's Avatar
Default Help me with my LS problem.
Ok...so there is no checke engine light...yet the car hesitate between 1k-2k rpm...its like a sudden sputter and then once I go to higher rpms it is not really there anymore. It starts happening about 15 minutes of city driving stop and go. ANy ideas what this might be? Is it soemthign with the distributor since it seems to be rpm related?
Old Oct 27, 2002 | 04:13 PM
lazy bum shaughn's Avatar
Default Re: Help me with my LS problem. (BoOsTeD_eK)
Maybe your fuel filter, or spark plug/wires or distributor.
Old Oct 27, 2002 | 04:35 PM
FifthGearOnline's Avatar
Default Re: Help me with my LS problem. (El Breako Dancero)
sounds like ignition to me, or the timing mabe?
Old Oct 28, 2002 | 04:48 AM
Default Re: Help me with my LS problem. (FifthGearOnline.com)
back to the top for the guy
Old Oct 28, 2002 | 02:29 PM
Perfectionist's Avatar
You don't indicate the year and model, but have you checked the O2 sensor? I had surging/bucking symptoms most noticeable at 25mph in 3rd gear. It was a lazy O2 sensor in my case. You could unplug yours and see if it goes away. This will of course set a CEL you'll have to clear later.
Old Oct 28, 2002 | 05:18 PM
BoOsTeD_eK's Avatar
Default Re: Help me with my LS problem. (Perfectionist)
fixed it...was a messed up spark plug throwing a misfire code 71..changed it and its running fine.
NosShootinHonda
Mar 2, 2009 06:38 PM
Kuniva
Feb 26, 2009 07:27 AM
itrintegra
Sep 24, 2007 07:31 PM
EF9 JAMS!!!
Aug 8, 2007 10:57 PM
92BlackSi
14
Apr 8, 2005 11:00 AM
