Hasport's H22-powered CRX
Old Jul 28, 2005 | 12:53 PM
hatchO's Avatar
Default Hasport's H22-powered CRX
You guys think its still worth putting a h22 in a crx even with the hasport mounts coming out? So wat are your pro's and con's..(Came out from Sport Compact Car Magazine)
in the magazine it's instructed to even take out your stereo? what?
Old Jul 28, 2005 | 12:57 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Hasport's H22-powered CRX (hatchO)
um there are atleast 5 threads about this posted a week did you really need a new one?
And I don't even understand what the question is because your asking will it be good to swap an h22 now mounts are coming out???
SCC blows never read it again it kills your brain cells
Old Jul 28, 2005 | 01:07 PM
90rexSi's Avatar
im going to do the swap actually im saving up for it right now. I met a guy in mtown who works for hasport and drove the crx he says everything works great and the handling is great too. So yea for sure good words about it and recomend it to anyone who has a rex and the money.
Old Aug 25, 2005 | 05:48 AM
djnikko's Avatar
Default Re: Hasport's H22-powered CRX (90rexSi)
I am from the UK and have been sourcing parts for almost a year to do this swap. I have been holding out for the hasport mounts as my fabrication skills are *****! plus I want everythign lined up right as to avoid other problems.
I want to boost my h22 once its in the CRX also, but am having difficulty with the radiator, you think a slanted 92-95 del sol radiator would work? If not i'll have to find someone with a tig welder to shorten the thing, any suggestions?
Old Aug 25, 2005 | 05:55 AM
CRX Toad's Avatar
Default Re: Hasport's H22-powered CRX (djnikko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">um there are atleast 5 threads about this posted a week did you really need a new one?
And I don't even understand what the question is because your asking will it be good to swap an h22 now mounts are coming out??? </TD></TR></TABLE>
I'm with you Ace. Do a little searching and you will info on H22 CRX. Maybe they want you to take the stereo out to put in the cable shifter BS.
Old Aug 25, 2005 | 06:47 AM
Loki12's Avatar
*shakes head*...
Old Sep 6, 2005 | 01:18 AM
djnikko's Avatar
Default Re: (CRX Junkie)
Does anyone have an item/part number for the driveshafts Hasport used in this swap? I know it was the driveshaftshop.com. Do I just call up and say give me some of what they had?
I know you can use stock accord/integra axles but would prefer to do things properly first time round as these are going to see alot of power/vibration.
Thanks in advance
Old Sep 6, 2005 | 02:10 AM
TH33G4MON3's Avatar
all i've seen is my friends hatch h22... but if there are mounts... I'm going to do it...
Old Sep 6, 2005 | 02:12 AM
TH33G4MON3's Avatar
where can you get these mounts... or put up a site when they do come out where you can get them thanx
Old Sep 6, 2005 | 06:40 AM
djnikko's Avatar
Default Re: Hasport's H22-powered CRX (TH33G4MON3)
The mounts can be purchased through HASPORT, you need to get yourself on the order list. I ordered mine last wednesday and am not recieving them till November/December time. The part number for the mount kit is listed in septembers Sport Compact Car. Thanks to NGChris for sending me a copy oversea's top guy
Anyone know about the dirveshafts? I'll email the driveshaft shop now, lets keep this thread dedicated to the way HASPORT did things in their guide this makes it easier to follow for everyone
Old Sep 6, 2005 | 06:43 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">I want to boost my h22 once its in the CRX also, but am having difficulty with the radiator, you think a slanted 92-95 del sol radiator would work? If not i'll have to find someone with a tig welder to shorten the thing, any suggestions? </TD></TR></TABLE>
Or you could just get a PWR shorty radiator from http://www.full-race.com
Old Sep 6, 2005 | 06:49 AM
djnikko's Avatar
Default Re: Hasport's H22-powered CRX (BlueShadow)
Thanks Blueshadow i'll check them out
Can anyone call the driveshaft shop for me on 1-800-564-2244, I am from the UK so this costs me a pretty penny to do so. I am basically wanting to know (im sure others do too) the part number of the driveshafts used in the HASPORT H22 CRX swap.
You help would be most appreciated
Old Sep 6, 2005 | 06:57 AM
djnikko's Avatar
Blueshadow - is that the 92-00 Civic half sized radiator? Is that likely to be any shorter?
I'll email full-race see if I can get some part numbers to post up also.
Thanks
Old Sep 6, 2005 | 07:15 AM
BlueShadow's Avatar
It's this one right here:
http://www.full-race.com/catal...d=481
Comparison pic of the PWR shorty rad next to a Fluidyne EG rad and the OEM EG rad.
Old Sep 6, 2005 | 07:19 AM
b18-c-rx's Avatar
I used the shorty radiator but it still didnt clear my dp (b18c), so i had to slide it down into the corner. the radiator now just barely clears the dp (1 cm or so).
Old Sep 6, 2005 | 03:56 PM
The DX Rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">The mounts can be purchased through HASPORT, you need to get yourself on the order list. I ordered mine last wednesday and am not recieving them till November/December time </TD></TR></TABLE>
how much are they??? and by chance do you have the part number?
Old Sep 6, 2005 | 04:31 PM
subydoored's Avatar
Default Re: Hasport's H22-powered CRX (The HF Rex)
ok guys i been doing reasearch on this myself i do have some links for you to read should help . oh ya one more thing anyone willing to donate their SCC issue to me for i was slow to seeing that issuc.
https://honda-tech.com/zerothread?id=711900
https://honda-tech.com/zerothread?id=1220132
https://honda-tech.com/zerothread?id=1225486
https://honda-tech.com/zerothread?id=1224211
If you find anymore useful search link or other websites just post the link.
Old Sep 7, 2005 | 12:25 AM
djnikko's Avatar
Default Re: Hasport's H22-powered CRX (subydoored)
The mounts are $599 from what I remember. The part number is in SCC, I shall have a look and post it up.
Im sure they'll sell back issues of SCC on their website? If not I'll try scanning it and putting it up on here
Old Oct 2, 2005 | 11:38 AM
D15powerd's Avatar
Trust me guys, save your cash now! I went for a ride in Brian's h22 CRX (SCC one) and i was shocked to say the least. IMO this is a K-series for your little rex for half the cost. A poor man's K20. All he has on it are I/H/E and that thing pulled like a ***** all the way to redline. The downside is you need to do a little hacking and pounding to make it fit but the end result is a 200hp+ beast that you can shut the hood over. Talk about sleeper! Riding in that crx has me thinking about selling my B-powered EG. For $5000 including the price of the car you could have one mean ride. I'm personally not looking forward to doing the wiring for all those harnesses, but i'll be happy knowing you will all be making cocky people look stupid
-Dan at HASport
Old Oct 2, 2005 | 12:32 PM
smutmonger's Avatar
"sport compact kills your brain cells"
that is the funniest **** i've heard all day!
Old Oct 2, 2005 | 12:41 PM
upfrontperformance's Avatar
Default Re: Hasport's H22-powered CRX (D15powerd)
Try an H22 Rex with a S1 Transmission, that will give the K guys a run for there money!
Ron
/\Front
Old Feb 6, 2006 | 06:57 AM
hybrid ef's Avatar
Default Re: Hasport's H22-powered CRX (upfrontperformance)
hmm... so if he did an h2b what mounts would he use with the b series trans...??? any one got an h2b rex on here?
Old Feb 6, 2006 | 09:31 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: Hasport's H22-powered CRX (hybrid ef)
My EF 88-91 Civic/Crx H22A motor mount kit $449 shipped US. Comes with alternator/tensioner bracket kit for your choice to run the D series alternator or H series alternator on the H22. Also comes with the clutch cable/hydro conversion bracket and detailed instructions with pictures. We also make the EF H22A traction bar system.
Facts of my kit: No firewall hitting, 1 custom axle which Raxles.com sells for the swap, Great ground clearance and alxe alignment and engine weight distribution.
---------&gt; http://www.ExplicitSpeedPerformance.net
antballs420
Sep 28, 2008 04:38 PM
integrawow
May 11, 2007 06:31 AM
gettocrx
13
Dec 9, 2005 02:09 PM
EFresh
Mar 16, 2004 09:23 AM
CRX_VTEC
May 23, 2002 10:39 PM
