something going on with my timing??
Old Jul 27, 2005 | 10:31 PM
jdm420da6's Avatar
Default something going on with my timing??
sup guys and girls...i had a question on my ignition timing that i hope someone can answer...when my cam gears are at zero, my timing is so far advanced that i cant retard it anymore with the distributor...and everything is at tdc even the cams, of course,...so what i did was i retarded my cam gear about -2 deg. and adjusted the distributor...so now my timing is dead on...now...my question is...why is is so far advanced when the gears are zero and everything is at tdc?...im just sitting here....scratching my head...wondering whats going on....can someone please explain..?
im still new, and researching on how to seriously tune motors..so if this is an obvious answer....im sorry in advance
Old Jul 27, 2005 | 11:07 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: something going on with my timing?? (jdm420da6)
Something here doesn't seem right.... are you sure everything is where its supposed to be?
Old Jul 28, 2005 | 09:49 AM
jdm420da6's Avatar
Default Re: something going on with my timing?? (JDM_Ej)
yeah im sure i put everything together right...im still new in tuning motors but well experienced when putting them together..., im thinking tho, that my since the camgears dont have a tdc mark on em, (but they have marks on both sides of each gear to align em on the sides) i may have installed em....upside down? perhaps? how would it even fire...i really dont know...but the car runs really good but it could probaly run alot better if i can just figure this out.
Old Jul 28, 2005 | 11:00 AM
Sliced Beard's Avatar
I am telling you from experience: redo yur timing belt settings......your cam is off one tooth from being in time with your crank. It will run but not very well with it off one tooth and you will have severe timing issues as you are having at this very moment.
Old Jul 28, 2005 | 05:58 PM
jdm420da6's Avatar
Default Re: something going on with my timing?? (DirtySol)
my motor already jumped a tooth and i had to retime it....now im on this problem..havent touched it since...i made sure that the cams were lined up at the cam gears....and the car does run fine...makes power all the way to 8500...maybe i should use the stock cam gears?? think itll help?
Old Jul 30, 2005 | 06:59 AM
jdm420da6's Avatar
BUMP
Old Jul 30, 2005 | 07:47 AM
PrettyLude's Avatar
compare the stock cam gears versus the aftermarket ones you have to see if the marks and the keyways are the same
Old Jul 30, 2005 | 12:16 PM
jdm420da6's Avatar
i see
Lazydsm
Feb 6, 2003 06:47 AM
honda8882
Sep 29, 2002 11:28 AM
1.8Tities
Sep 8, 2002 03:32 AM
Fooser
Apr 15, 2002 03:22 PM
