Engine stall at stop...
Old Jul 29, 2005 | 07:44 PM
Johnny.'s Avatar
Widow's Son
Default Engine stall at stop...
The car: 2001 Altima
Engine: KA24DE with A/T
Problem: When coming to a stop, the engine will idle extremely low and at times stalls out.
Possible problems?
I was thinking something to do with the vacuum lines perhaps?
Any help/advice would be appreciated. Thanks!!
-Johnny
Old Jul 29, 2005 | 08:19 PM
BS 22's Avatar
Default Re: Engine stall at stop... (JohnnyIS300)
double post, ban
Old Jul 29, 2005 | 08:23 PM
SwampThing's Avatar
i have this problem with my civic and so does my friend. he figured out it was the Throttle Position Sensor i believe. he took it out, cleaned it and bow it work. you can also hit the AC button and it will idle normal, then turn ac off.
EL Vap133's Avatar
Do you got a CEL? Any codes?
Old Jul 29, 2005 | 08:25 PM
Johnny.'s Avatar
Widow's Son
No CEL.
Old Jul 29, 2005 | 08:26 PM
SwampThing's Avatar
i already answerd the question dammit, let me go back to post whoring.
Old Jul 29, 2005 | 08:27 PM
civic_hatch's Avatar
Could be a fuel problem, not fuel at idel things like cloged injectors fuel filter or a possibly a dirty throttle plate. When you are at WOT do you have any problems with hesitation? Or is this only an idle problem.
Old Jul 29, 2005 | 08:28 PM
Johnny.'s Avatar
Widow's Son
Default Re: (civic_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_hatch &raquo;</TD></TR><TR><TD CLASS="quote">Could be a fuel problem, not fuel at idel things like cloged injectors fuel filter or a possibly a dirty throttle plate. When you are at WOT do you have any problems with hesitation? Or is this only an idle problem.</TD></TR></TABLE>
I noticed a slight hesitation at WOT.
Old Jul 29, 2005 | 08:40 PM
Johnny.'s Avatar
Widow's Son
Default Re: (SwampThing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwampThing &raquo;</TD></TR><TR><TD CLASS="quote">i have this problem with my civic and so does my friend. he figured out it was the Throttle Position Sensor i believe. he took it out, cleaned it and bow it work. you can also hit the AC button and it will idle normal, then turn ac off.</TD></TR></TABLE>
Well, we had the AC on when the car stalled.
Old Jul 29, 2005 | 08:46 PM
Default Re: (JohnnyIS300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyIS300 &raquo;</TD></TR><TR><TD CLASS="quote">
I noticed a slight hesitation at WOT. </TD></TR></TABLE>
Then you might be looking at a fuel problem low fuel pressure probably. Another words you're not getting enough fuel at idle cause the car to die and not enough fuel to keep the car at WOT, could also be a dirty throttle plate not letting enough air in take your TB off and clean it in there with some carburetor cleaner. It can also be an array of problems from clogged injectors or fuel filter worn fuel pump etc. It could also be a TPS sensor but usually that's alot more erratic hesitation rather then slight and highly unlikely to break or be moved if you havent messed with it. If you have a fuel pressure Gage try hooking that up at idle you should see anywhere between 36 and 42 psi.
SwampThing's Avatar
well your **** is fucked up then. il go with vacum lines. but the vacum lines would make no sense unless someone connected them wrong. and everytime i've put them on in the wrong order or whatever it sounds like my car has a cam, not low *** idle.
Old Jul 29, 2005 | 08:48 PM
Well, we had the AC on when the car stalled. </TD></TR></TABLE>
Having the A/C on causes more engine drag and would only worsen an already existing problem, the car shouldn't die even with the A/C on though.
Old Jul 29, 2005 | 08:49 PM
SwampThing's Avatar
well when i turn mine on then turn it off the idle returns to normal.
Old Jul 29, 2005 | 08:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwampThing &raquo;</TD></TR><TR><TD CLASS="quote">well when i turn mine on then turn it off the idle returns to normal.</TD></TR></TABLE>
It's normal for idle to drop when you turn the A/C on a 4cyl. car but even though the car shouldnt die.
Old Jul 29, 2005 | 08:57 PM
SwampThing's Avatar
im saying my idle is already really low, then i turn the ac on and turn it off and the idle i back to normal.
Old Jul 29, 2005 | 08:58 PM
Frozen E's Avatar
H-T White Ops
new plugs and wires
Old Jul 29, 2005 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwampThing &raquo;</TD></TR><TR><TD CLASS="quote">im saying my idle is already really low, then i turn the ac on and turn it off and the idle i back to normal.</TD></TR></TABLE>
Thats some weird stuff right there I've never seen that, so quickly turning the the A/C on then off fixes it for you huh intresting.
Old Jul 29, 2005 | 09:06 PM
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">new plugs and wires</TD></TR></TABLE>
haha nice sig.
Old Jul 29, 2005 | 09:44 PM
Sabbotage's Avatar
EGR valve stuck open maybe? I just had a similar problem and thats what it was.
Old Jul 29, 2005 | 10:08 PM
Earthworm Jim's Avatar
Quick way to fix it......get a Honda
Old Jul 30, 2005 | 12:16 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: Engine stall at stop... (TheGeneral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGeneral &raquo;</TD></TR><TR><TD CLASS="quote">Quick way to fix it......get a Honda </TD></TR></TABLE>
that is not the answer. have you tried having the alternator tested? it may possibly be an electrical issue. in hondas, we have an electrical load detector. when the alternator is about to take a ****, these symptoms can happen.
B18CivicDriver
Apr 20, 2006 05:48 PM
DamienM
Jul 20, 2005 10:19 PM
Aphelion
Feb 26, 2005 07:41 AM
winterbear09
May 4, 2004 10:11 AM
RineRacing
11
Feb 16, 2004 11:13 AM
