coilover compression question
Old Feb 18, 2002 | 07:43 PM
hobo79's Avatar
New User
Default coilover compression question
my friend says that if i get fround control street coilovers that i would need a shop to compress my stock springs to get them off. i thought you only need to compress them if i plan to put aftermarket springs, not for coilovers though. someone help me. putting them on civic coupe 98. also, if it is true, then how much would it run me to put coilovers on?
Old Feb 18, 2002 | 08:10 PM
nfn15037's Avatar
Default Re: coilover compression question (hobo79)
Youll need a compressor to remove the stock springs from the shocks. But not to reassemble with the GCs. An a side note, i would not recommend running the Ground Controls on stock shocks. Itll blow the shocks in no time and it will ride like crap. Just my .02.
Old Feb 18, 2002 | 08:30 PM
hobo79's Avatar
New User
Default Re: coilover compression question (nfn15037)
well, my plan is to drop about an inch for now. will the shocks still go with that? if i get shocks, my plan is to get KYB AGX shocks. So how much will it cost for someone to take my stock spring and replace them with ground control coils?
Old Feb 18, 2002 | 08:40 PM
nfn15037's Avatar
Just wait until you can do it right; ie-shocks too. Its going to suck with GCs on stock hocks, ive told this to 2 of my friends, who didnt listen, and they regretted it. You are gonna have to pay 2x labor also. My suggestion would be to rent a compressor from AutoZone or some place and do it yourself. Its a no brainer job. Good luck
Old Feb 18, 2002 | 09:16 PM
hobo79's Avatar
New User
wow, u can rent one.....didnt know that, good advice. THANKS!
Old Feb 18, 2002 | 10:09 PM
nfn15037's Avatar
YEah, its like $40, but they give all your $ back when you return it, so its basically free.
Old Feb 19, 2002 | 06:55 AM
REDBARON's Avatar
You don't actually need them to remove the springs, but it's safer if you do. I personally have never used one to remove the springs. I just use the old aim and shoot method, and it works every time. I just did my brothers this weekend and it worked fine. You also don't need them to install lowering springs or coilovers. Just my .02
ady2glude707
Suspension & Brakes
24
Nov 6, 2012 07:50 PM
ady2glude707
Dec 14, 2011 03:27 PM
SweetSnowGurl
May 27, 2004 05:48 PM
93CX
12
Jul 13, 2003 12:59 PM
MiracleWhip
13
Jul 8, 2003 11:12 AM
