HELP Putting my a/c system BACK IN!!!!!!
Old Jul 24, 2005 | 08:56 PM
918-Hatch's Avatar
Colorado <3
Default HELP Putting my a/c system BACK IN!!!!!!
Like the title says, I want to put my a/c system back in my car. I have all the lines under the dash still on the car. Can I still use them? people have told me that I need new lines because these have been open for years without somthing covering the ends of the hoses.. Is this true?
And what will I need to get as for as lines,Compressor,brackets,freeon....ect
Thanks
Old Jul 24, 2005 | 09:24 PM
underb00steg6's Avatar
Default Re: HELP Putting my a/c system BACK IN!!!!!! (918-Hatch)
do a search for a/c. someone had a thread on ac and explained how lines that have been opened have to vaccuumed out. a shop does that.....you need compressor ,condensor, all the lines under the hood, dryer,and brackets.
Old Jul 24, 2005 | 09:31 PM
EKtypeRhaTcH's Avatar
you can still use em, but your gonna have to lube the o rings up with refrigerant oil. i just did that too and now its COLD! hehehe
Old Jul 24, 2005 | 11:19 PM
918-Hatch's Avatar
Colorado <3
Good deal. Any links.. I did a search and came up with nothing.
Old Jul 24, 2005 | 11:21 PM
si_lee's Avatar
Default Re: (918-Hatch)
yea, using your old lines is fine, the only thing that needs to be replaced is the drier and o-rings but everything else can be reused, hopefully they have no leaks.
Old Jul 24, 2005 | 11:27 PM
96CivicBoostCoupe's Avatar
Default Re: (si_lee)
it'll be fine, it get vacuumed when they fill it to pull all the **** out of it
Old Jul 24, 2005 | 11:32 PM
918-Hatch's Avatar
Colorado <3
I was just going to add the stuff myself
Old Jul 25, 2005 | 11:04 AM
918-Hatch's Avatar
Colorado <3
Bump for a good link to help out maybe?
Old Jul 26, 2005 | 02:00 AM
918-Hatch's Avatar
Colorado <3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 918-Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Bump for a good link to help out maybe?</TD></TR></TABLE>
Old Jul 26, 2005 | 02:39 PM
918-Hatch's Avatar
Colorado <3
up again
Old Jul 26, 2005 | 04:31 PM
fillin your self is easy, but stil;l a good idea to get it vacuumed, mold n **** will grow in your system
Old Jul 26, 2005 | 04:50 PM
95DxSi-R2
Guest
Posts: n/a
you have to flush the lines before you do anything, i hope you have an air compressor, and an air gun. you need a bottle of flush from the parts store, put alittle bit in the a/c line at a time and blow it out with compressed air. Do that to all your lines, the condensor and evaporator, i don't know if civics use orfice tubes or expansion valves, but i would get a new one anyway. get all new o-rings, and a reciever dryer. you say your going to do it yourself so i assume you don't have an a/c machine? so u can't vaccum it down. when your adding the freon, turn the bottle upside down. Add what the label says and good luck
93integrastock
Aug 30, 2007 06:25 PM
ABCVTEC
Jul 30, 2007 09:31 AM
NazVil86
Sep 20, 2006 08:57 PM
hialeahzbg
Jun 3, 2004 06:58 AM
