HELP Putting my a/c system BACK IN!!!!!!
Colorado <3
Like the title says, I want to put my a/c system back in my car. I have all the lines under the dash still on the car. Can I still use them? people have told me that I need new lines because these have been open for years without somthing covering the ends of the hoses.. Is this true?
And what will I need to get as for as lines,Compressor,brackets,freeon....ect
Thanks
Thanks
Re: HELP Putting my a/c system BACK IN!!!!!! (918-Hatch)
do a search for a/c. someone had a thread on ac and explained how lines that have been opened have to vaccuumed out. a shop does that.....you need compressor ,condensor, all the lines under the hood, dryer,and brackets.
Re: (918-Hatch)
yea, using your old lines is fine, the only thing that needs to be replaced is the drier and o-rings but everything else can be reused, hopefully they have no leaks.
Colorado <3
Re: (918-Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 918-Hatch »</TD></TR><TR><TD CLASS="quote">Bump for a good link to help out maybe?</TD></TR></TABLE>
Guest
Posts: n/a
you have to flush the lines before you do anything, i hope you have an air compressor, and an air gun. you need a bottle of flush from the parts store, put alittle bit in the a/c line at a time and blow it out with compressed air. Do that to all your lines, the condensor and evaporator, i don't know if civics use orfice tubes or expansion valves, but i would get a new one anyway. get all new o-rings, and a reciever dryer. you say your going to do it yourself so i assume you don't have an a/c machine? so u can't vaccum it down. when your adding the freon, turn the bottle upside down. Add what the label says and good luck
93integrastock
08-30-2007 06:25 PM
TenaciousC
09-26-2002 08:30 AM
