gsr head on b16 block?
Old Jul 23, 2005 | 04:53 PM
beaneg6's Avatar
Default gsr head on b16 block?
one of my frineds wants to put a gsr head on a b16 block. he is claiming this will make a high compression b16?! just wondering some of the specs? what headgasket to use and what head bolts gsr or b16? any help from anyone
Old Jul 23, 2005 | 05:18 PM
fasthatchb18c1's Avatar
Default Re: gsr head on b16 block? (beaneg6)
Searching is not that hard.... really its not
https://honda-tech.com/zerothread?id=1253133
https://honda-tech.com/zerothread?id=1153299
https://honda-tech.com/zerothread?id=1140171
use this to find your compression http://www.c-speedracing.com/h...c.php
Old Jul 23, 2005 | 06:04 PM
PURPLETERROR aka BIGMATT's Avatar
you gain roughly .5 points in compression, you can use the gsr or b16a headgasket and you use the b16a head bolts, alot of work for minor gains
Old Jul 23, 2005 | 06:49 PM
red-eg6's Avatar
Default Re: gsr head on b16 block? (PURPLETERROR)
lol thats a waste of time. bigger liter head on lower liter block = less compression
Old Aug 4, 2005 | 02:37 PM
bleedblue94's Avatar
Default Re: gsr head on b16 block? (red-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">lol thats a waste of time. bigger liter head on lower liter block = less compression </TD></TR></TABLE>actually the combustion chamber of the gsr head is smaller then that of a b16 head...hence you are upping the compression ratio...not lowering it....im running this right now in my daily driver
EgxHaTcHxGsR
Nov 22, 2009 10:51 PM
civcexcoupeblack
Jan 23, 2005 08:20 PM
boostin4door
Jul 27, 2004 08:46 AM
prjctCIVIC
May 23, 2002 01:13 PM
SSDCRX
Jul 5, 2001 03:08 PM
