VTEC problems i think?
Old Jul 21, 2005 | 08:42 PM
WhiteVX_EG6's Avatar
Default VTEC problems i think?
I recently put a D16z6 into my 94 civic VX, when i first put the motor in i didnt have a 4 wire o2 sensor so i had to use the VX engine harness with the 5 wire o2 and of course i was throwing a code, VTEC worked, i had no real problems besides the CEL. I got a 4 wire o2 and i put my Si wire harness on and did the 5 wire o2 fix. No CEL's or anything BUT, i'm hitting rev limiter at 6500rpm but VTEC is working, do i have to pin the VTEC spool solenoid and the pressure switch myself to make vtec work right so i can rev to 7500rpm or is there something else wrong? i'm using a p28 btw. thanks.
Brandon
Old Jul 21, 2005 | 09:21 PM
hybridmath's Avatar
Default Re: VTEC problems i think? (WhiteVX_EG6)
p28 ecu revs out at 6500 if you want higher rev limit you have to chip your ecu or replace but why would you want to rev to 7500 rpm its a d16z6 not b16/b18
Old Jul 21, 2005 | 09:22 PM
Stoich EG2's Avatar
Default Re: VTEC problems i think? (steve6025)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve6025 &raquo;</TD></TR><TR><TD CLASS="quote">p28 ecu revs out at 6500 if you want higher rev limit you have to chip your ecu or replace but why would you want to rev to 7500 rpm its a d16z6 not b16/b18</TD></TR></TABLE>
p28's redline at 7200rpm smart guy.
Old Jul 21, 2005 | 09:24 PM
Hatch It's Avatar
Default Re: VTEC problems i think? (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">p28's redline at 7200rpm smart guy.</TD></TR></TABLE>
GOTEEEEEEEM!
Old Jul 21, 2005 | 09:26 PM
Hatch It's Avatar
Your talking about the 92-95 Civic CX ECU, which isnt a p28, but does rev to 6,500....
correct me if im wrong
Old Jul 21, 2005 | 09:27 PM
red-eg6's Avatar
Default Re: VTEC problems i think? (Hatch It)
my p28 redlines at 9200 and i run a jdm d15b and my vtec runs hard up to 7500 and 8000 and i can beat my friends b16 hatch with i/e 1st 2nd and 3rd i pull on him.
Old Jul 21, 2005 | 09:30 PM
Stoich EG2's Avatar
Default Re: VTEC problems i think? (red-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">my p28 redlines at 9200 and i run a jdm d15b and my vtec runs hard up to 7500 and 8000 and i can beat my friends b16 hatch with i/e 1st 2nd and 3rd i pull on him.</TD></TR></TABLE>
you make no power over 7500 guarenteed. unless it's not a stock motor...
Old Jul 21, 2005 | 09:58 PM
Ok lets stay on topic, anybody have any ideas on what my problem might be?
Old Jul 21, 2005 | 10:06 PM
red-eg6's Avatar
Default Re: (WhiteVX_EG6)
jus get a damn dx harness and use the 1 wire o2 sensor. i like them better and there cool casue they create there own power but jus wire the vtec straight to the ecu lol
Old Jul 21, 2005 | 10:07 PM
red-eg6's Avatar
Default Re: (red-eg6)
i did it in mine and works perfect
Old Jul 21, 2005 | 10:11 PM
I have my 4 wire o2 hooked up and all of that so that problem is solved, so basically you're saying just to pin the vtec solenoid and pressure switch. but the vx came with vtec from honda but maybe the pins are different?
Brandon
Old Jul 21, 2005 | 10:40 PM
Hatch It's Avatar
Okay, did you bother to find an EX harness from a 92-95?
Im not THAT good with this stuff, but i am pretty sure if you just go and get a harness for the D16Z6 it will be perfect...
Dont go splicing and cutting, your guranteed for CEL's if you do it incorrectly....
My biggest suggestion is to get the harness for that motor so its easy plug and play
Good luck....again
Old Jul 24, 2005 | 11:50 PM
I'm already pinned for vtec, i'm thinking it's something being retarded in the fuel or ignition system because i'm throwing no code for what it's doing, i'm not even throwing codes at all. thanks anyways guys.
Brandon
Old Jul 24, 2005 | 11:52 PM
BTW i'm using a AEM high flow fuel rail, that's the only thing i have on my motor right now that isn't stock, i'm still on stock regulator, injectors, etc... that wouldn't make it cut out at high rpm's would it?
ProjectRustyEF
Mar 24, 2008 12:19 PM
rmriffle
10
Mar 9, 2008 10:47 PM
projsectEF
14
Oct 1, 2006 06:10 PM
sammydigital
Feb 21, 2006 03:19 PM
ITRnorway
Jul 4, 2005 11:28 AM
