how to use this tester
i have one of those cheap testers that look like a pen.
what parts of the car can i clamp the clamper down to?
what part do i touch with the tip, the positive or negative?
will it still work with solder on it?
What are you trying to test?
Usually, the clamp goes on a ground point and the probe on the wire you are testing for power. If youre testing a ground wire then its reversed.
Its just a test light - you complete a circuit and the light comes on. I made my own out of wire and a bulb.
If you are checking to see if a wire has 12 volts then place the clamp on a known good ground and probe the wire. If it lights up then you have 12 volts on that wire. If you are checking for ground on a wire then put the clamp on a known 12 volts and probe the wire. If it lights up then theres your ground. Hope this helps
It needs to be a bolt that is attached to the chassis (metal to metal contact), not say one of the screws that holds the interior plastic together.
Electrical solder is conductive, so yes.
ZipTieGUy
24
Mar 12, 2006 04:49 PM
