Need help removing tie rod end from strut...(pics)
Old Jul 16, 2005 | 09:55 AM
Ev_eezy's Avatar
Default Need help removing tie rod end from strut...(pics)
This is an '02 Civic Ex coupe 95k miles (I know, we drive a lot).
Trying to replace the struts, but the tie rod ends won't detatch from the strut! WTF?!
Ok I've never done this before, so your help is much appreciated
This is what I'm trying to remove (for those who might not call it a tie rod)
and I did search first
Old Jul 16, 2005 | 10:05 AM
vtecpoweredsol's Avatar
use a ball joint popper thing (idk wut its really called) it looks like a giant 2 prong fork and the 2 prongs have flat sides and they're banked just put that in there and hammer it.
oh and whatever you do, dont hit the bottom with a hammer thinking it will pop out, you'll most likely strip the threads
Old Jul 16, 2005 | 10:07 AM
Ev_eezy's Avatar
Default Re: (vtecpoweredsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpoweredsol &raquo;</TD></TR><TR><TD CLASS="quote">use a ball joint popper thing (idk wut its really called) it looks like a giant 2 prong fork and the 2 prongs have flat sides and they're banked just put that in there and hammer it.
oh and whatever you do, dont hit the bottom with a hammer thinking it will pop out, you'll most likely strip the threads</TD></TR></TABLE>
Yeah just bought the fork an hour ago.....after hammering the bottom hahahaha this day is gonna suck! Thanks for the response. I'll try again.
Old Jul 16, 2005 | 10:12 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (Ev_eezy)
if you got a tap and die set you can bang the bottom a little
Old Jul 16, 2005 | 10:14 AM
turbo_ef9's Avatar
take a really big hammer.. hit that pickle fork as hard as you can.. if not, hit the part that the rod connects to.. the part that is off the strut itself.. do not hit the ball joint or the stud off the ball joint.. anything but that use your muscles!
Old Jul 16, 2005 | 06:32 PM
TurboEG215's Avatar
Default Re: (eli_vang)
find a big a$$ hammer and smack the hell out of the knuckle where the tie rod goes into and it will pop out by itself. Trust me hit it hard and nothing will happen I do this everyday
Old Jul 16, 2005 | 06:34 PM
daklown's Avatar
Dat Dere Cell Tech
I always used a sledge hammer
Old Jul 16, 2005 | 09:36 PM
Mike04Civic's Avatar
Default Re: Need help removing tie rod end from strut...(pics) (Ev_eezy)
ummm rubber mallet maybe?
wursterracing
Dec 27, 2009 04:34 PM
Smash03
Dec 11, 2007 11:01 AM
HuskerHybrid
33
Dec 19, 2006 08:22 PM
atg1290
Suspension & Brakes
Sep 24, 2006 02:47 PM
SpoonFedHatch
12
Mar 28, 2005 05:35 PM
