I need Help
Old Feb 16, 2002 | 08:52 PM
HaUTSaauce's Avatar
New User
Default I need Help
I keep getting a check engine light a few seconds after i start the car up. I tried checking the Code but its not throwing ne codes. I also hear a strange noise comming from the ECU when the car is running. NE ideas?
Old Feb 17, 2002 | 06:34 AM
jdm_latino's Avatar
Default Re: I need Help (HaUTSaauce)
what do you drive and what is in it
does it drive?
Old Feb 17, 2002 | 12:11 PM
HaUTSaauce's Avatar
New User
Default Re: I need Help (jdm_latino)
Crvtec in a 96 gsr
It drives completely fine
Old Feb 17, 2002 | 12:14 PM
HaUTSaauce's Avatar
New User
there is no noise comming from the ECU i was trippin but there is a CEL when the car is running but not when i check it. So i dunno?
Old Feb 17, 2002 | 06:13 PM
tinkerbell's Avatar
the CEL should come on for 2 seconds, then go off.
HTH,
t..
[Modified by tinkerbell, 1:14 PM 2/18/2002]
Old Feb 18, 2002 | 12:06 PM
HaUTSaauce's Avatar
New User
Default Re: I need Help (tinkerbell)
HTH,
t..
when i check te CEL i get nothing (no flases at all ) but when i drive the car the CEL stayes on
Old Feb 18, 2002 | 12:16 PM
Greyout's Avatar
I am a B-series idiot... but is it OBD II?
Old Feb 18, 2002 | 04:56 PM
HaUTSaauce's Avatar
New User
Default Re: I need Help (JDM LUDE)
yes it is OBDII
Old Feb 18, 2002 | 05:59 PM
Kamin's Avatar
no when hit the ignition
the cel comes on for 2 seconds then goes away
its normal.
Old Feb 18, 2002 | 08:20 PM
HaUTSaauce's Avatar
New User
Default Re: I need Help (KAMiN)
its normal.
but the CEL is staying on it dosent go off
Old Feb 19, 2002 | 01:20 PM
HaUTSaauce's Avatar
New User
ttt
Old Feb 19, 2002 | 06:42 PM
tinkerbell's Avatar
in some cases this check engine light (with no codes) relates to an ECU problem...
does the car run well?
t..
Old Feb 19, 2002 | 10:06 PM
HaUTSaauce's Avatar
New User
car still runs very strong i dont think that there r ne problems with the ECU (crossing fingers) i think it might be something simple like an o2 sensor
Old Feb 20, 2002 | 10:31 PM
HaUTSaauce's Avatar
New User
top
91ef_civic
Mar 22, 2011 02:33 PM
19cIvIc94
Jan 21, 2009 10:31 AM
benjamin
Oct 29, 2004 09:31 PM
See Are X
Jul 13, 2003 09:26 PM
BoostedGSRBubble
May 10, 2002 08:40 AM
