WHats wrong here? Bogging car
Old Jul 14, 2005 | 07:27 PM
Crasian's Avatar
Default WHats wrong here? Bogging car
Okay people, heres the problem. I have a 93 civic dx, i bought the car as a shell and put in a nice d16z6 that was known to be running before i installed it in my car. So i install my motor and take it for a spin, the thing will not rev past around 2000 rpm while i drive, it sucks cuz i can hardly make it up hills and i can only go 80 km/h, if i press the peddle down to far suddenly the car will just bog out. Now, i have tried changing the fuel pump, FPR, dizzy, sparkplugs, sparkplug wires. I am also getting a code 43 which is a "Fuel Supply System defective or malfunctioning fuel supply system" How can i fix taht code? Please someone help me, i wanna drive this thing at somewhat of a normal speed PLEEEEEASE!!!
Old Jul 14, 2005 | 08:02 PM
B18C5-EG's Avatar
Default Re: WHats wrong here? Bogging car (Crasian)
My friend had the same problem he couldent go past 2k turned out to be a bad clutch master cylinder try that
Old Jul 14, 2005 | 08:16 PM
urquidezj's Avatar
Default Re: WHats wrong here? Bogging car (B18C5-EG)
how did you do your wiring? did you add the vtec and all that? maybe some vacuum lines start with the simple things. as for your code, maybe a dirty gasstank? or u need a new fuel filter?
Crasian's Avatar
clutch master cylinder???? how could that be the culprit????
Old Jul 14, 2005 | 08:18 PM
Crasian's Avatar
Default Re: WHats wrong here? Bogging car (urquidezj)
checked all vacuum lines, they are all good, made sure i didnt cross the TPS and map sensor connectors, my vtec is all wired up rite.... fuel filter is brand new, i am clueless as to what it could be now, i have tried so many things
Old Jul 14, 2005 | 08:30 PM
urquidezj's Avatar
missing ground? there are some sensor plugs on the back of the intake mani and three of them i think and u can missconnect them and it will mess things up, O2 sensor also. checcked for clogged vacuum lines? those are hard to find or cracked ones.
Old Jul 14, 2005 | 09:33 PM
Crasian's Avatar
anyone else?
Old Jul 14, 2005 | 10:38 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Crasian)
Clutch master cylinder?? That doesnt make sense but ok.
Wiring. Make sure the ECU isn't bad or anything either.
Old Jul 14, 2005 | 11:56 PM
jdmb1697ek's Avatar
Default Re: (JDM_Ej)
my car bogged like at a bitch at 5000 and would redline early at 6000 in my b16 turned out to be one bad fuel injector.
Old Jul 15, 2005 | 12:16 AM
JDMlyfestyle's Avatar
did you remember to hook up ur thermostat ground?
that will cause serious bogging issues.
BTW ur code 43 is most likely your o2 sensor which can throw your car into limp mode.
Old Jul 15, 2005 | 05:42 AM
Crasian's Avatar
i will go ckeck that now thank u
Old Jul 15, 2005 | 06:08 AM
khmboostedeh2's Avatar
check the plugs yet?
Old Jul 15, 2005 | 06:14 AM
Crasian's Avatar
yupp and tried new injectors too, just waiting for the car to cool down rite now so i can try my other O2 sensor
Old Jul 15, 2005 | 10:35 AM
scott92hatch's Avatar
u could be getting to much gas or have fouled spark plugs
Old Jul 15, 2005 | 12:00 PM
Crasian's Avatar
Default Re: WHats wrong here? Bogging car (scott92hatch)
i just changed the O2 sensor and that didnt work already tried differnt spark plugs too WTF is wrong with this thing!
Old Jul 15, 2005 | 01:44 PM
Crasian's Avatar
Someone please give me the answer! I have treid everything!!!
Old Jul 15, 2005 | 01:57 PM
pull the plugs, and look down into the cylinders. Make sure everything looks good. If you spot any water, you found your problem.
Old Jul 15, 2005 | 09:42 PM
Crasian's Avatar
umm, dont thats it.... ive been driving the car around the last 2 days
Old Jul 16, 2005 | 04:18 AM
Crasian's Avatar
so i guess im screwed...
Old Jul 16, 2005 | 06:04 AM
1517cc sohcvtec's Avatar
what distributor are u using because ignition system timing is equally important as the fuel delivery system.
Old Jul 17, 2005 | 08:37 AM
Crasian's Avatar
i am using a stock dizzy for a d16z6, i even tried the whole dizzy off my friends civic with d16z6 and same problem continued
Old May 16, 2011 | 01:03 PM
chucktowncrown's Avatar
hey man im having the same prob with my b18c5, i pulled the plugs and on one of the plugs there was what appeared to have water on it. what does this mean and how can i fix it??
Old May 16, 2011 | 05:17 PM
Izo's Avatar
Izo
I'm guessing head gasket. Also make a new thread about it - The modding police will tell you in 5 nano secs :D
salman
15
Nov 17, 2006 10:55 AM
vietxdragon
Sep 13, 2006 01:40 PM
crnimacak
Dec 30, 2005 12:21 PM
cincispeedemon
Nov 22, 2004 05:51 PM
memphiss13
Jan 5, 2002 09:18 PM
