WHats wrong here? Bogging car
Okay people, heres the problem. I have a 93 civic dx, i bought the car as a shell and put in a nice d16z6 that was known to be running before i installed it in my car. So i install my motor and take it for a spin, the thing will not rev past around 2000 rpm while i drive, it sucks cuz i can hardly make it up hills and i can only go 80 km/h, if i press the peddle down to far suddenly the car will just bog out. Now, i have tried changing the fuel pump, FPR, dizzy, sparkplugs, sparkplug wires. I am also getting a code 43 which is a "Fuel Supply System defective or malfunctioning fuel supply system" How can i fix taht code? Please someone help me, i wanna drive this thing at somewhat of a normal speed PLEEEEEASE!!!
Re: WHats wrong here? Bogging car (B18C5-EG)
how did you do your wiring? did you add the vtec and all that? maybe some vacuum lines start with the simple things. as for your code, maybe a dirty gasstank? or u need a new fuel filter?
Re: WHats wrong here? Bogging car (urquidezj)
checked all vacuum lines, they are all good, made sure i didnt cross the TPS and map sensor connectors, my vtec is all wired up rite.... fuel filter is brand new, i am clueless as to what it could be now, i have tried so many things
Re: WHats wrong here? Bogging car (Crasian)
missing ground? there are some sensor plugs on the back of the intake mani and three of them i think and u can missconnect them and it will mess things up, O2 sensor also. checcked for clogged vacuum lines? those are hard to find or cracked ones.
did you remember to hook up ur thermostat ground?
that will cause serious bogging issues.
BTW ur code 43 is most likely your o2 sensor which can throw your car into limp mode.
Re: WHats wrong here? Bogging car (scott92hatch)
i just changed the O2 sensor and that didnt work already tried differnt spark plugs too WTF is wrong with this thing!
Re: (Crasian)
hey man im having the same prob with my b18c5, i pulled the plugs and on one of the plugs there was what appeared to have water on it. what does this mean and how can i fix it??
crnimacak
12-30-2005 12:21 PM
memphiss13
01-05-2002 09:18 PM
