eg rear trailing arm
Old Jul 14, 2005 | 09:52 AM
yakitori's Avatar
Default eg rear trailing arm
can I use the trailing arm off of my drum brakes and put them on disc brakes?i heard it fits and it looks like it'll fit but i wanna be sure before I rip everything apart
thanks
Old Jul 14, 2005 | 09:56 AM
nighttrain33's Avatar
Default Re: eg rear trailing arm (yakitori)
Yeah, it'll fit. Good luck with the install and with getting the bolts loose.
-Shane
Old Jul 14, 2005 | 09:59 AM
yakitori's Avatar
Default Re: eg rear trailing arm (nighttrain33)
any sugestions on how to get then lose? i was planning on using my impact driver to get the star shapped ones loose
Old Jul 14, 2005 | 10:13 AM
How many times do I have to explain it?!? j/k
Get a torch and some WD-40 and you should be all set. Just WD-40 the bolt, then heat it with the torch, obviously being careful since the WD-40 is FLAMMABLE. Heat it for a good 30-45 seconds. Then try to get it off. It may take a couple of tries, but it has always worked for me. And try as much as you can not to break any of the bolts. I know that the trailing arm-to-suspension bolts are about $10 a piece.
-Shane
cehcivic15
14
Jun 18, 2012 12:50 PM
stripes777
Aug 11, 2008 07:50 PM
. o 69 o .
17
Apr 4, 2004 12:47 PM
Soda Popinski
Mar 30, 2004 05:18 PM
no2unenolife
Sep 19, 2003 03:59 AM
