injector idle issue: H22 345cc
1st gen B16a non-obd car
peak and hold injectors.
4G H22A lude injectors rated at 345cc
anybody using them..??? without electronic assistance..
i hear honda ECUs cant handle injectors over 310cc.
is this true.???
[Modified by Giuseppe, 2:57 PM 2/16/2002]
is this true.???
gtcali
i havent gotten around to it, ill just plug them in
and fire her u, and see first hand, i just posted
to get feedback b4 actually doing it,
i cant afford the hondata unit,
im a broke student.!! lol
Forget electronic controls - just drop the idle fuel pressure with an adjustable regulator or drill a little relief hole in the stock FPR. A Hondata would make up nearly half your budget from what I understand.
Seriously to get the most tuning for your $$ I think a good adjustable FPR would be your best bet.
Seriously to get the most tuning for your $$ I think a good adjustable FPR would be your best bet.Trending Topics
Between the B&M and the relief hole you should be able to adequately drop your idle FP and keep your full-throttle FP high enough to take advantage of the injectors. If that doesn't pan out, consider pulling out the stock FPR completely and replace it with a Cartech 20005 or Vortech SFMU which has fully adjustable starting FP and rise rate.
Good luck!
Good luck!
uhh
i already have the cartech 20005 unit.using it for my turbo application...
its a rising rate unit..and i also have the B&M fpr also,
am i talking stupidity here... doh.!
i guess i am... so it'll idle like a charm then...
thank
thank
Lei Siew Long
Feb 8, 2002 08:01 PM
