oem map?did a search
Old Jul 8, 2005 | 01:08 AM
jure's Avatar
Default oem map?did a search
How much boost can oem map senzor handle..I saw people talking 10 psi some people said 14 psi..What's the truth?
Old Jul 8, 2005 | 01:10 AM
used2baracer's Avatar
Default Re: oem map?did a search (jure)
we should put a pump to it and see how much boost we can build before it explodes
Old Jul 8, 2005 | 01:15 AM
Si Shane's Avatar
Default Re: oem map?did a search (used2baracer)
1.75bar map sensor. 1bar of regular atmosphere on top of you and 3/4 of a bar. 14/4~3.5
3.5x3~11
it reads to ~11 pounds
Old Jul 8, 2005 | 01:42 AM
jure's Avatar
Default Re: oem map?did a search (Si Shane)
thanx man, can somebody confirm that?
Old Jul 8, 2005 | 01:58 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jure &raquo;</TD></TR><TR><TD CLASS="quote">thanx man, can somebody confirm that? </TD></TR></TABLE>
That's usually how you figure out how much boost xx.xx bar MAP sensor will handle.
1 bar = 29.5 in/hg of mercury = 14.5 PSI absolute
Think of it this way: a map sensor can handle xx amount of vacuum below atmosphric pressure, and xx amount of pressure above atmospheric pressure. You can measure pressure/vacuum in bar, in/hg or psi absolute. Your typical gauge setup usually measures vacuum in in/hg and boost in psi. But the numbers can be interchanged. Absolute vacuum is the lowest reading your MAP sensor can handle. From absolute vacuum to atmospheric is 1 bar/29.5in hg/14.5 PSI absolute. That's how I understand it anyways.
The easiest way I can explain it is to take your map sensor rating and subtract 1 bar. The remainder is how much boost pressure it is good for.
Example:
1.75 bar sensor = good for 0.75 bar or 10.8 psi of boost
2.5 bar sensor = good for 1.5 bar or 21.7 psi of boost
3 bar sensor = good for 2 bar or 29 psi of boost
5 bar sensor = good for 4 bar or 58 psi of boost
ashb82
Engine Management and Tuning
Sep 3, 2009 03:29 AM
laziebun
Jan 14, 2008 04:58 AM
vu337
Oct 24, 2005 04:50 PM
2ltrsnailpwr
Oct 26, 2003 07:11 PM
kell211
Oct 6, 2003 04:07 AM
