B&M FPR
It'll only be good if you want to increase fuel pressure as you can't decrease pressure with it - and since you're running an FMU, increasing static fuel pressure would be the last thing on my mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis »</TD></TR><TR><TD CLASS="quote">It'll only be good if you want to increase fuel pressure as you can't decrease pressure with it - and since you're running an FMU, increasing static fuel pressure would be the last thing on my mind.</TD></TR></TABLE> Does the FMU increase fuel pressure or just the quanity of fuel flowing when it senses boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">It greatly increases the fuel pressure when it sees boost. You don't want to run a FPR and an FMU. IMO you don't want to run an FMU at all.</TD></TR></TABLE>i may be able to afford hondata with the base map it comes with. but I heard it will run like **** until its tuned.
