fmu=fpr?
Old Jun 3, 2003 | 05:51 PM
xstalkrx's Avatar
Default fmu=fpr?
Is an FMU and FPR the same thing? I hear people talking about FMU's raising fuel pressure but I thought that was the job of the FPR??
Old Jun 3, 2003 | 05:56 PM
boosted92's Avatar
Default Re: fmu=fpr? (xstalkrx)
A fuel pressure regulator or FPR helps maintain a constant fuel pressure. A Fuel Management Unit or FMU is a rising rate reguator that boost fuel pressure in conjunction with manifold pressure. You typically run an FMU with a 1:1, 8:1 or 12:1 disc.
Old Jun 3, 2003 | 06:07 PM
xstalkrx's Avatar
which is used more commonly? Can you use them both at the same time?
Old Jul 17, 2003 | 09:51 PM
rota426's Avatar
Default Re: (xstalkrx)
I have the same question, I have a vortech 12:1 fmu, with a stock fpr, what should I do, and will the fmu do anything while the stock fpr is there?
BTW: I have a b18b1 teg ls and im running 6.5 lbs of boost.
Tia
Old Jul 17, 2003 | 10:17 PM
xstalkrx's Avatar
ya someone please help us here...although I will be using Hondata instead of the fmu and fpr
Old Jul 17, 2003 | 10:52 PM
Tofurky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xstalkrx &raquo;</TD></TR><TR><TD CLASS="quote">which is used more commonly? Can you use them both at the same time?</TD></TR></TABLE>
They both do something completely different.
The FMU is a boost dependant fuel regulator, meaning it raises the fuel pressure a certain number of psi for ever lb of boost. It is not adjustable, aside from changing out the discs.
So with a 12:1 disc in your FMU, and you're running 6.5 lbs of boost. Then it will raise your fuel pressure 78 psi!
An FPR is not boost dependant. It will maintain a constant amount of fuel, regardless of how much boost you are running. An adjustable FPR will let you manually change your "idle" fuel pressure.
You can run both at the same time, because each does something different.
If you are not running any other form of fuel management then you will need to have an FMU.
Old Jul 17, 2003 | 11:01 PM
RuthlessEF-9's Avatar
it would be nice to have both if your going to go that route. the fmu will raise the fpr from what you have it set on the fpr
petarr
Sep 11, 2005 02:07 PM
88crxhfb16
Jul 7, 2005 02:21 PM
scartail
Oct 12, 2004 11:53 AM
taejin11
Jun 20, 2004 09:45 PM
evil_elmo
Oct 13, 2002 02:15 AM
