Putting a washer in my TiAL gate to get more pressure?
Old Jul 6, 2005 | 09:23 AM
.RTErnie's Avatar
Default Putting a washer in my TiAL gate to get more pressure?
Oh folks..I have a 14psi spring but I'd like to run near 18 psi. I have a 7psi small spring as well...I dont want to run 21psi, and my ebc is currently broken. SO. I was thinking that I could stick a washer on top of the spring and compress it more making the spring constant larger. you think a 1/4" spacer will be sufficient? or smaller?
Old Jul 6, 2005 | 09:28 AM
dustin's Avatar
Default Re: Putting a washer in my TiAL gate to get more pressure? (RTErnie Motorsports)
I have a small .25bar tial spring you can have. You'd just have to drive down here to get it
Old Jul 6, 2005 | 10:01 AM
tgreaves's Avatar
I would build one of those $5 boost controllers before I would go messing with putting washers in the wastegate..
Old Jul 7, 2005 | 12:09 PM
.RTErnie's Avatar
Default Re: Putting a washer in my TiAL gate to get more pressure? (tgreaves)
i have a Greddy Profec B, but it got burnt up in a nasty electrical surge.
I ended up just running 20 psi turned out it was a 6.25 psi spring :-P And it hauled ***. life is good.
Old Jul 7, 2005 | 12:15 PM
turboteg2nv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">
I ended up just running 20 psi turned out it was a 6.25 psi spring :-P And it hauled ***. life is good.</TD></TR></TABLE>
Nice lol
Old Jul 7, 2005 | 02:32 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">i have a Greddy Profec B, but it got burnt up in a nasty electrical surge.
Wait.... so you put a washer on top of the spring in your wastegate and it increased the boost from 6.25psi to 20psi?!
LoL... talk about a cheap boost controller!
Old Jul 7, 2005 | 02:54 PM
.RTErnie's Avatar
Default Re: Putting a washer in my TiAL gate to get more pressure? (EJ1 wilcox)
nah i took my small 6.25psi spring and set it inside of my 14psi spring....then put the top back on. 6.25+14psi=20.25
Old Jul 7, 2005 | 03:32 PM
mrbsponge's Avatar
why not just use a check valve or something similar to bleed off a tad bit of boost i wouldnt go messing with the wastegate
Old Jul 7, 2005 | 04:00 PM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">nah i took my small 6.25psi spring and set it inside of my 14psi spring....then put the top back on. 6.25+14psi=20.25</TD></TR></TABLE>
I love hearing **** like this. and it really works, thats sweet.
Old Jul 7, 2005 | 07:33 PM
EJ1 wilcox's Avatar
Default Re: Putting a washer in my TiAL gate to get more pressure? (88crxhfb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">I love hearing **** like this. and it really works, thats sweet.</TD></TR></TABLE>
On tial's web site it says you can combine the large and small springs to get a desired boost pressure.
I still wonder if the washer trick would work, I may try it on my car once I get the turbo back on there.
Old Jul 7, 2005 | 08:31 PM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
I still wonder if the washer trick would work, I may try it on my car once I get the turbo back on there. </TD></TR></TABLE>
I wonder too, I need to run 10 psi, and my MBC is crapping on me.
pcguy760
Jul 8, 2011 09:08 AM
D15Bbigred
Mar 11, 2007 10:05 PM
Bimmerman
May 7, 2005 06:45 PM
NORCALCVC
Feb 15, 2005 11:57 PM
yusoslo
Apr 22, 2004 10:53 AM
