CEL and Running Problem Help-!????
I just finished putting my head back on my car, i reattached all the connectors as i thought they went, but now it throws a check engine light as soon as you turn the key even before it ever was started- I have the odb1 conversion with a hondata s200 unit- I checked the code i got one long flash and 5 quick flashes, and maybe a 6 short flash- im taking that as a code 15 and a code 6- code 15 in my book sez no ignition signal output- possible faulty igniter- the car starts and runs fine until you give it gas, it acts like it hits a rev limiter at 2 grand, i have a wire plug i cant find a home for, its an oval grey plug with a yellow with blue stripe, green with black stripe, and white with black stripe? can anybody steer me in the right direction, everything is finished and it starts and idles fine, If you rev it slowly instead of mashing the pedal down u can slowly rev past 2 grand to about 4, so any help would be great-
Thanks
Ryan-
Thanks
Ryan-
Granny_shifter
18
Sep 17, 2012 08:08 AM
hondaxfresh7192
10
Mar 18, 2012 12:54 PM
