Won't rev past 3k, Please help
1997 Civic with a b20b motor. Just had the swap put in about a month ago. Car was running fine until today. I was driving and all of a sudden it wouldn't let me rev past 3k, and it bogged down the harder i would press the gas pedal. When i feather the pedal the car accelerates a little. Can someone please help me out? Thanks a lot.
Re: Won't rev past 3k, Please help
Also, it's throwing a CEL code 17 (vehicle speed sensor), it was throwing that when the car was running fine, so I'm not sure if that can be a factor or not.
When my car was running fine, the CEL would turn off every time I would turn off my car. It would stay off for a bit once I restarted the car, but would reappear when I ran it for a bit. I tried testing it with a paperclip and that's the only code that showed up.
You have a 97 honda is your motor obd1 ? Cause if im not mistaken you should have a obd 2 witch means your connector is underneath the steering wheel so where do you get a paper clip
obd2. It's a 98' motor. I tested the cel codes with the small connector next to the ecu. Is that not the correct place to get the codes?
Car is now revving past 3k, but still very sluggish. It feels like it's running on 3 cylinders or something. Checked spark plugs and they are all fine. Ideas?
granny shifter did you ever find out your problem my friend is having same problem in his eg hatch with b20 swap? he tried swapping ecus but no luck?
It turned out to be a short. The battery terminal runs straight to the fuse box, it connects to a couple of bolts. The bolts in the fuse box were loose. It was a bizarre solution. It all worked out after I tightened the bolts.
