Intake Manifold
Old Jun 25, 2005 | 08:09 PM
mcgee*'s Avatar
Cigarette Squad
Default Intake Manifold
alright just put in my new engine, d15b7; 94 Honda Civic Hatch... blow the other one so just replaced it.. well one of the vacumes isnt hooked up to the intake manifold..(top right) the piece where the vacum line plugs into broke, replacing tommorow, question is my intake manifold is spitting out radiator fluid from the intake manifold from the back.. any ideas what might this be, maybe just cause the vacum line isnt hooked up??, also car ran really hot when i took it for test drive after installin new engine.. (i opened the hood and it was steaming from all the fluid hitting the walls and stuff "is this why its over heating?" )
any ideas what it might be?
Old Jun 25, 2005 | 08:38 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: Intake Manifold (So_Skilled_01)
Old Jun 25, 2005 | 09:30 PM
mcgee*'s Avatar
Cigarette Squad
bump before sleep
Old Jun 25, 2005 | 11:15 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by So_Skilled_01 &raquo;</TD></TR><TR><TD CLASS="quote">alright just put in my new engine, d15b7; 94 Honda Civic Hatch... blow the other one so just replaced it.. well one of the vacumes isnt hooked up to the intake manifold..(top right) the piece where the vacum line plugs into broke, replacing tommorow, question is my intake manifold is spitting out radiator fluid from the intake manifold from the back.. any ideas what might this be, maybe just cause the vacum line isnt hooked up??, also car ran really hot when i took it for test drive after installin new engine.. (i opened the hood and it was steaming from all the fluid hitting the walls and stuff "is this why its over heating?" )
any ideas what it might be?</TD></TR></TABLE>
It's not too clear exactly which vacuum line you have off from you description. Is it the one for the brake booster? Or is it a smaller one for like the fuel pressure regulator? As for your coolant issue, sounds like you didn't reconnect one of the lines to it's proper location. I'm guessing it's your IACV which is located on the back of the intake manifold. The reason you are overheating is because all of your coolant is no longer in the engine or radiator, it's all over the car and the road. Take your time, double check to make sure you have everything hooked up and nothing leaking.
genuser
Feb 16, 2015 06:03 PM
hulk_22
Dec 11, 2006 01:03 PM
silentdaredevil2
Jan 3, 2006 03:14 PM
speedy94ex
11
Sep 21, 2004 07:49 PM
tea
Oct 24, 2003 05:01 AM
