all 4 fuel injectors click, car finally cranks PLEASE help cars almost right
Old Jun 21, 2005 | 08:01 AM
ncskate's Avatar
Default all 4 fuel injectors click, car finally cranks PLEASE help cars almost right
cars set to 16BTDC. its a y7-y8 mini-me. i know the timings perfect because i set it my self with a timing light and jumped the ecu thing and everything. this car has been an on going problem and now it idles smooth at 600-750 rpm. the only thing is ALL four fuel injectors are clicking loudly and the car cuts off on me when i give it gas. what could be the problem?
Old Jun 21, 2005 | 08:28 AM
EvilPinkEye's Avatar
Default Re: all 4 fuel injectors click, car finally cranks PLEASE help cars almost right (ncskate)
sounds like car not getting enough gas..pump even. sensors on the TB...
Old Jun 21, 2005 | 09:35 AM
ncskate's Avatar
Default Re: all 4 fuel injectors click, car finally cranks PLEASE help cars almost right (EvilPinkEye)
well what would go out and cause this but not throw a CEL? any clue? im thinking it might be something dealing with the distributor still because im using a used one from a friend they all the wires were chopped and spliced to find the signal for a tach i suppose a while back so the wiring could be bad but ive checked it amillion and one times. other than that the map sensor could be out but wouldnt that throw a cel?
edit and i know the CEL light is good because when i jump it to set the timing the check engine light stays on...
Old Jun 21, 2005 | 11:02 AM
ncskate's Avatar
i have a 94 automatic civic 4door EX parts car... is the fuel pump the same for that as in my 93 si delsol? i also ihave another 94 delsol si but its been sitting out for so long i doubt that fuel pumps any good. or will they not go bad like that
i changed out the MAP sensor no luck, i changed distributor internals from a z6 EVERY thing from the z6 in to my distributor because the z6 wont fit to the y8 still no luck could the FPR cause it not to get enough fuel? i tried something i read about taking the vaccum hose off the FPR and cranking but my car wouldnt crank with out it
Old Jun 21, 2005 | 11:05 AM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
did you replace the injectors/wiring with the head swap? maybe you switched the ground and signal wires for each injector?
Old Jun 21, 2005 | 12:18 PM
ncskate's Avatar
Default Re: all 4 fuel injectors click, car finally cranks PLEASE help cars almost right (2000psi)
na obd1 im still using the z6 intake manifold
Old Jun 23, 2005 | 01:09 PM
FastGsr95's Avatar
i would get a fuel injection service from ur dealer
Old Jun 23, 2005 | 07:17 PM
ncskate's Avatar
Default Re: all 4 fuel injectors click, car finally cranks PLEASE help cars almost right (FastGsr95)
i dunno how good that will go ive never takin this car to a dealer ship for anything plus i thought if u do stuff like minime swap's dealerships wouldnt work on it. around here i think its like that... well anyhow i had it working and everything reving right and getting gas staying on etc. i left for a day came back and my number 1 and 3 injectors wont fire now
logie4270
14
May 11, 2010 02:28 PM
96 EX
12
Jul 3, 2008 05:33 PM
Chronicsinners
25
Mar 7, 2006 03:59 PM
crxforum
Aug 30, 2004 07:01 AM
JpiZz0
13
Feb 13, 2003 06:19 PM
