fuel problem i think...need help
yesterday i noticed my car was idling funny. i let it warm up and i proceeded to drive to work... i noticed when i floored it, it hesitated then picked up again...today it did the same thing but worse the check engine light was flashing and a strong smell of gas was in my car. i stopped at a light and the car stalled. i gave it gas and it stayed at 1000 rpms then picked up again...whats goin on fellas?car idles weird and when i give too little gas it bucks...could this be spark plugs, clogged injectors, cap and rotor or ecu. Any assistance would be much appreciated.
thanx
jp
thanx
jp
Re: fuel problem i think...need help (Daniel)
my car does the same thing....im thinkin its the fuel pump? but when i try to redline my car it wont....it sputters...does yours do this to?? mine stalls sometime to......someone help us both out...haha
Re: fuel problem i think...need help (89civichatchback)
limp mode .... whut is that? yeah im soo scared i dont even go past 5000 rpms my car sounds horrible....didnt pull the code yet...gonna go to honda monday.
Re: fuel problem i think...need help (jPs vTec)
no, pull the code yourself. jump the plug behind your kick panel and read the flashes on your dashboard. Go to http://www.jdmfan.com to see what the codes mean or how to jump your ECU. And limp mode is the status your engines goes into when the car's ECU senses something is wrong. It makes your run REALLY rich and lowers the rev limit. The engine is almost undriveable but just enough so that you can at least "limp" home or to a shop or whatever.
Its hard to tell without looking at it but it sounds to me like your not getting enough spark.Pulling the code is a good idea to make sure
Re: fuel problem i think...need help (DA MUGEN 1)
well i changed the plugs just got the fuel filter today i'll keep u guys posted on whut happens
thanx
jp
thanx
jp
Jesus Christ,
PEOPLE, when your car runs like a sack of *** on a hot sunny day, PLEASE DON'T BEAT ON IT. Your liable to make your problem worse.
FIX the damn problem.
For both of you, it sounds like you have a leak some where in your fuel system. Check your injector seals, both the ones that go into the intake manifold and the the o ring seals on the top of the injectors where they go into the fuel rail.
Replace your fuel filter.
If you have CEL light, get the code, and see if it helps you out.
If you are smelling fuel, find the leak.
Re: fuel problem i think...need help (TommyV)
umm....ok anyways thanx for all the help fellas it was the fuel filter and the cel is off now
thanx again
jp
thanx again
jp
Si Arn
08-14-2008 11:53 AM
