cooling fan issue...
Old Jun 20, 2005 | 05:48 PM
bon3's Avatar
Default cooling fan issue...
Newbie here so i apologize if this sounds dumb...
My cooling fan does not turn on when its suppose to, instead it only turns on with the A/C fan when i turn on the A/C. Any suggestions...???
Thanks.
Old Jun 20, 2005 | 06:37 PM
sporkcrx's Avatar
Default Re: cooling fan issue... (bon3)
How do you know it should be turning on.
Old Jun 20, 2005 | 07:44 PM
Suck my DX's Avatar
Default Re: cooling fan issue... (sporkcrx)
check ur fuse for it...check for continuity in the wires...if they are not receiving power...find the open and repair it
Old Jun 21, 2005 | 04:38 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Year? Model? Please move a little to the left. I can't see your car.</TD></TR></TABLE>
Some year/models have 2 fan switches & a timer module. Some have only one fan switch at the thermostat. Unplug that fan switch, jumper the wire with a paperclip. Key on, that should make the fan run. Or maybe not, depending on what model or year...
Old Jun 21, 2005 | 07:14 AM
bon3's Avatar
its an 91 accord lx.
I checked the fuses, it all seems to be alright.
Old Jun 21, 2005 | 10:38 AM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How do you know it should be turning on.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How do you know it should be turning on.</TD></TR></TABLE>
Old Jun 21, 2005 | 01:24 PM
TorGa3ighT's Avatar
isn't the fan for the AC a separate fan in some cars? my last car had a 2nd fan for the A/C...my car would start to overheat, so I would turn the AC on, and then fan for the a/c would blow inside the engine bay and cool down my car.
Old Jun 21, 2005 | 01:44 PM
JimBlake's Avatar
Default Re: (TorGa3ighT)
Some years they're both connected to come on together, some years separately. That's why it's nice to know what car you're talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bon3 &raquo;</TD></TR><TR><TD CLASS="quote">its an 91 accord lx.</TD></TR></TABLE>I think that year has 2 switches & a timer module, but I don't have a '91 so I'm not really sure.
Old Jun 21, 2005 | 06:00 PM
Crazydave's Avatar
Default Re: (JimBlake)
In cars with a single fan,
the fan will turn on when the A/C is turned on. Therefore the fan is operating correctly.
The temperature switch for the fan is most likely the culprit.
I suggest replacing the switch.
Another problem if the temp switch is in the radiator, could be the thermostat not opening and the radiator temp always being low (because the thermostat won't let the water from the engine into the radiator), therefore the switch would not tell the fan to turn on.
jlowellintegra
May 30, 2011 07:52 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
mike93eh2
13
Feb 17, 2007 04:23 PM
mikebish86
Feb 1, 2005 06:26 PM
wsiracerz
Jun 7, 2004 12:08 AM
