Spedometer not working...odometer also???
Old Jun 20, 2005 | 04:52 PM
CiviC RacecaR's Avatar
Default Spedometer not working...odometer also???
I just got this car and since the spedometer didnt work when I bought it, does that mean that the odometer hasn't been working also? Could this car actually have different mileage then the odometer says? Thanks.
Old Jun 20, 2005 | 05:12 PM
civicpacrat's Avatar
Default Re: Spedometer not working...odometer also??? (CiviC RacecaR)
oh yes the actual mileage stopped when speedo stopped.
Old Jun 20, 2005 | 05:13 PM
1995Ex_Sedan's Avatar
Check to make sure the speed sensor is good. I believe its ontop of the transmission.
Old Jun 20, 2005 | 06:29 PM
by the way if you've got no cel most likely speedo head. could be wiring but doubtful unless wrecked. still doubtful.
Old Jun 20, 2005 | 06:52 PM
neutron91's Avatar
Default Re: (1995Ex_Sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Ex_Sedan &raquo;</TD></TR><TR><TD CLASS="quote">Check to make sure the speed sensor is good. I believe its ontop of the transmission.</TD></TR></TABLE>
... my speedo was acting up... bouncing like crazy... i thought it was my cluster since i had no cel so i was kinda mad... so just for kicks i punched it to see if vtec still worked... cause if the speed sensor was good and the cluster was bad vtec would still engage... well it revved to 4800 and wouldnt do anything more... so i pulled the vss and it had water in the connector... dried it out popped it back in and all was well
Old Jun 20, 2005 | 09:52 PM
TsukubaDreams's Avatar
speed sensor would throw a cell and make your car run like ****, check all your hookups in the back of the dash.
Old Jun 20, 2005 | 10:42 PM
vsmhatched's Avatar
yeah, alos if your car has vtec, it wouldn't be engaging it its not working. I had this on my car and it threw a code 17 (obd 1) which is VSS sensor
Old Jun 21, 2005 | 03:46 AM
neutron91's Avatar
Default Re: Spedometer not working...odometer also??? (TsukubaDreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TsukubaDreams &raquo;</TD></TR><TR><TD CLASS="quote">speed sensor would throw a cell and make your car run like ****, check all your hookups in the back of the dash.</TD></TR></TABLE>
wrongo... it wont always throw a code as in my case... and the vss has nothing to do with how the car runs... so it will run fine... unless you have vtec then it wont engage
doubleoazn03
Sep 5, 2008 10:33 PM
aziaticvang
Jan 13, 2008 06:35 PM
hspoon
Aug 30, 2006 07:52 PM
APEX CRX
Jul 27, 2005 01:38 PM
unknown0001
Feb 28, 2005 02:43 PM
