shimming vtec oil pump
Old Jun 20, 2005 | 03:44 PM
PURPLETERROR aka BIGMATT's Avatar
Default shimming vtec oil pump
Im going to shim my oil pump for more pressure, should i place the shim inside the relief valve, or on the top of the sealing bolt?
Old Jun 20, 2005 | 08:06 PM
theEGkid's Avatar
on the bottom of the oil pump theres going to be an allen head. Undo that and inside there should be a spring and a piston. Put a washer or 2 in there to increase oil pressure in the motor.about 1mm will bring it 2 around 80 psi at wot
Old Jun 21, 2005 | 07:40 AM
Default Re: shimming vtec oil pump (PURPLETERROR)
any more info?
Old Jun 21, 2005 | 08:03 AM
tgreaves's Avatar
The idea is to push the spring harder to get more oil pressure.. So putting a washer in between the bolt and the spring will bump it up..
civic-4-ges's Avatar
Default Re: shimming vtec oil pump (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">The idea is to push the spring harder to get more oil pressure.. So putting a washer in between the bolt and the spring will bump it up..</TD></TR></TABLE>
Correct, however there is a very fine line between adequate shim, and too much shim
Old Jun 21, 2005 | 08:11 AM
Default Re: shimming vtec oil pump (civic-4-ges)
Omniman told me to use a 1-1.5mm shim
Old Jun 21, 2005 | 08:17 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">
Correct, however there is a very fine line between adequate shim, and too much shim</TD></TR></TABLE>
Yep.. On my B16A motor there was a crush washer in between the bolt and the pump so I just took that out and used some hondabond to stop it from leaking.. Removing the washer bumped the pressure up..
Old Jun 21, 2005 | 08:26 AM
how much of a pressure increase did you get when removing the crushwasher?
Old Jun 21, 2005 | 08:31 AM
Anyone weight the benefits of pressure VS the loss of volume???
Old Jun 21, 2005 | 09:16 AM
I dont think there will be a significant loss of volume, as the shim keeps the relief valve from bypassing the oil back to the sump.
Old Jun 21, 2005 | 09:48 AM
tgreaves's Avatar
Agreed.. If your getting higher pressure at the bearings and at the gauge then since you didnt change the clearance of the bearings then you had to increase flow..
Old Jun 21, 2005 | 11:22 AM
theEGkid's Avatar
im gonna test my oil pressure today. im having a wicked v tec problem and thought the type r pump and shim would work. seems like theres a block somewhere
Old Jun 21, 2005 | 11:40 AM
tgreaves's Avatar
Default Re: (SmoothlilHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoothlilHatch &raquo;</TD></TR><TR><TD CLASS="quote">im gonna test my oil pressure today. im having a wicked v tec problem and thought the type r pump and shim would work. seems like theres a block somewhere</TD></TR></TABLE>
A wicked vtec problem huh, can you define this wicked vtec problem..
Old Jun 21, 2005 | 12:14 PM
Default Re: (tgreaves)
Well, the shim is in, and im putting everything back together, hopefuly this works.
Old Jun 21, 2005 | 01:24 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: (PURPLETERROR)
I was going through the same problem with my vtec not working because lack of oil presure. It turned out the vtec solinoid screen was gunked up with metal shavings and wasent letting oil through. Its alot easer than pulling the oil pan and everything I would try it first before I start shimming stuff
Old Jun 21, 2005 | 03:49 PM
Default Re: (mr.GREEN)
pump is shimmed, oil pressure is 78 psi at 3-4k and 80-85 psi all the way to 9500, Looks like it solved my problem.
JDMCRX
Feb 19, 2008 03:43 AM
gawath
Dec 23, 2005 05:40 PM
daveedd357
Jul 23, 2005 08:51 AM
-KangaRod-
Mar 22, 2004 02:52 PM
SoloSol
Aug 7, 2003 01:35 PM
