Help with mini-me swap
Old Jun 16, 2005 | 09:34 AM
Kengee's Avatar
Default Help with mini-me swap
My son did a mini-me swap and the idle is fluctuating. He replaced the distributor, timing belt, plugs, wires, pcv valve and cleaned the throttle body. He checked for vacuum leaks and found nothing. He tried a differant ecu and still nothing changed.
He is at his wits end and is ready to put his old head back on. He read something about jumping something with a paperclip by the ecu to reset the timing. Any suggestions with this problem would greatly be appreciated.
Old Jun 16, 2005 | 09:42 AM
337 GTI 1.8t's Avatar
Default Re: Help with mini-me swap (Kengee)
if you can, please give the chassis it is in, ecu code you are using, bottom end code and head code....
for instance, 1998 Civic with d16y7 sohc non-vtec (stock) bottom end, d16y8 sohc vtec head and p2p d16y8 ecu.
With this info, we can start to sort possible issues
Old Jun 16, 2005 | 01:18 PM
Kengee's Avatar
Default Re: Help with mini-me swap (337 GTI 1.8t)
It is a 95 civic-d15b7 bottom, d16z6 vtec head, and he tried hia original ecu d15b7 and he put in a p28.
Old Jun 16, 2005 | 01:34 PM
USDMGD3!'s Avatar
i just did this swap to about a week ago...
are u throwing any check engine light?
i would check ur fast idle valve and iacv...
Old Jun 16, 2005 | 01:47 PM
Kengee's Avatar
Default Re: Help with mini-me swap (OZ Rally)
the check engine light does not come on. He checked fast idle valve and the iacv. The car ran great prior to the conversion. I am beginning to think from what he tells me they did not put the timing belt on correctly according to the procedures in the book. He also has a question about jumping something by the ecu to reset the timing one of his freinds told him about.
Old Jun 16, 2005 | 01:56 PM
USDMGD3!'s Avatar
ive never heard about jumping something on the ecu to reset the timing.
the only thing i read about jumping something on the ecu is if u have a jdm motor u jump the vtec oil pressure switch to the vtec solenoid to by pass it or something like that...
try this out https://honda-tech.com/zero...age=1
Old Jun 16, 2005 | 02:02 PM
Kengee's Avatar
He was told there is a harness by the ecu that is a 2 wire plug and your supposed to jump it with a paper clip.
Old Jun 16, 2005 | 02:10 PM
USDMGD3!'s Avatar
the service connector? u jump that to check ur timing with the timing light...
https://honda-tech.com/zerothread?id=1171263
*edit
also is the fast idle connected to any hose? when i did mine i didnt have it connected but then connected with a Y adapter...
Old Jun 16, 2005 | 02:19 PM
Kengee's Avatar
ok so you only do that when you check the timing it doesnt effect the timing. Do you think the fitv valve could be dirty and maybe the coolant needs to be bled?
Old Jun 16, 2005 | 02:24 PM
USDMGD3!'s Avatar
nope it doesnt effect the timing...
i would try that link out and see that helps, i did that to my motor b4 i did the mini-me and it worked.
Old Jun 16, 2005 | 02:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kengee &raquo;</TD></TR><TR><TD CLASS="quote">ok so you only do that when you check the timing it doesnt effect the timing. Do you think the fitv valve could be dirty and maybe the coolant needs to be bled?</TD></TR></TABLE>fitv plastic screw could be loose, i forget, do those have FITV underneath?....also, yes, air gaps in the coolant could cause a loping idle...
Old Jun 16, 2005 | 04:52 PM
FERIOkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 337 GTI 1.8t &raquo;</TD></TR><TR><TD CLASS="quote">air gaps in the coolant could cause a loping idle...</TD></TR></TABLE>
i bet this could definatly be your problem, make sure all coolant lines are secure and that there is no air in the system at all, good luck
tech410
24
Jun 7, 2012 08:10 PM
91HCRX
Jan 7, 2012 05:14 AM
ProjectEG8
11
Oct 28, 2007 01:00 PM
luckecharm2004
Nov 12, 2004 10:51 PM
C-speed
Feb 19, 2002 12:44 PM
