How to install manifold studs
Old Jun 16, 2005 | 05:31 AM
93si-hybrid's Avatar
Default How to install manifold studs
What is the best way to install new studs for my header on gsr. Thanks
Old Jun 16, 2005 | 06:41 AM
snatch's Avatar
Default Re: How to install manifold studs (93si-hybrid)
Right where the stud and the head meet, there might be a small place without any threads, and it's flattened on opposite sides on the stud. You should be able to fit a small open ended wrench around there, and turn them out and back in. Hopefully that makes sense. It's similar to the end of a shock, and holding onto that with a small wrench to keep the shock from turning.
Old Jun 16, 2005 | 07:02 AM
Default Re: How to install manifold studs (******)
alright thanks for the help.
Old Jun 16, 2005 | 07:52 AM
337 GTI 1.8t's Avatar
an easier way is to double-nut the stud and screw it in by turning the top nut...the bottom nut will keep the top nut from turning down the stud. This is how i put in all studs, unless they are like the new ARP which now have a spot for a hex key.
Old Jun 16, 2005 | 08:04 AM
snatch's Avatar
Default Re: How to install manifold studs (337 GTI 1.8t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 337 GTI 1.8t &raquo;</TD></TR><TR><TD CLASS="quote">an easier way is to double-nut the stud and screw it in by turning the top nut...the bottom nut will keep the top nut from turning down the stud. This is how i put in all studs, unless they are like the new ARP which now have a spot for a hex key.</TD></TR></TABLE>
This would work as well, maybe even better since you won't be turning a wrench right next to the head.
Old Jun 16, 2005 | 08:23 AM
ok thanks guys for your help. i will try that tonight.
Old Jun 17, 2005 | 05:58 PM
PrettyLude's Avatar
double nut works, but i have this tool called a stud remover from snap on, and man it works alot better than the double nut method
Old Jun 17, 2005 | 07:34 PM
snowseeker's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">double nut works, but i have this tool called a stud remover from snap on, and man it works alot better than the double nut method</TD></TR></TABLE>
The poly lock type stud remover? Those work good.
Old Jun 18, 2005 | 07:40 AM
PrettyLude's Avatar
its the kind that slips over the stud, and as you tighten or loosen it will grab the stud and turn it, works damn good if you ask me
Old Jun 18, 2005 | 07:42 AM
PrettyLude's Avatar
http://buy1.snapon.com/catalog...talog
Old Jun 18, 2005 | 04:23 PM
flatblackracing's Avatar
yea those stud removal tools work great! If you have access to MATCO tools then buy the one they sell, it's only like $50 and works awesome. I use my se almost everyday.
thatcivic96
May 17, 2014 09:50 PM
turbo-crx
Sep 1, 2008 07:26 AM
timmy0tool
10
Dec 19, 2007 03:25 PM
dnasol
Jul 1, 2005 04:44 PM
Beave0101
Jul 10, 2003 08:06 PM
