How to install extended wheel studs
Old Dec 19, 2003 | 02:32 PM
dnasol's Avatar
Default How to install extended wheel studs
does anyone know how to install extended wheel studs. Thanks
Old Dec 19, 2003 | 02:46 PM
MackSpeed-616's Avatar
Default Re: How to install extended wheel studs (dnasol)
the hub has to be removed from the car. then its just a matter of whacking the old ones out and pressing the new ones in.
Old Dec 19, 2003 | 05:17 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnasol &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to install extended wheel studs. Thanks
Remove front wheels, unbolt and hang front calipers, remove rotor screws and remove front rotors,remove axle nuts, pull front hubs-a hub puller recommended. Press or hit old studs out-put lugnuts on them beforehand if you want to save the threads. Press or hit new studs in. Reinstall everything in the reverse order.
Old Dec 19, 2003 | 09:54 PM
dnasol's Avatar
thanks for the help. do you know how long it may take to change all 16.
Old Dec 19, 2003 | 10:00 PM
b19coupe's Avatar
Default Re: (dnasol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnasol &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help. do you know how long it may take to change all 16.
It depends on the tools available and the skill of the person. Also, it will take a lot more time if the car is back East where everything rusts together. Here in Cali, it would take less than an hour for a semi-skilled mechanic with decent equipment.
Old Dec 23, 2003 | 11:25 AM
Junkiii Ek's Avatar
its not hard bro..i changed all 16 in likean hr but my rears are drums not disc....good luck
Old Dec 23, 2003 | 12:10 PM
KILLAMAN's Avatar
Default Re: (Junkiii Eg)
WTB: SPOON TRANNY (N3E) will pay top dollars....
WELL HOW MUCH ARE YOU WILLING TO PAY
Old Jun 29, 2005 | 05:01 PM
NAturalDC2's Avatar
Default Re: How to install extended wheel studs (b19coupe)
i got my 5lug off the car already i have taken everything off but the only problem is that the area for me to take out the stock studs, it looks like something is in the way i think its the hub dont know what you call it anyone help?
Old Jun 30, 2005 | 02:27 PM
SiR831's Avatar
Default Re: How to install extended wheel studs (NAturalDC2)
would you guyz recommend tack welding the studs to the spindle?
Old Jun 30, 2005 | 03:08 PM
TrackSpeedRacing's Avatar
Default Re: How to install extended wheel studs (SiR831)
its recommended that you do so however I got away with just pressing them in. good luck
Old Jun 30, 2005 | 03:15 PM
THCk20eg's Avatar
tack weld them for sure. you dont want those bitches spinning on you at the track.....
Old Jun 30, 2005 | 03:19 PM
SiR831's Avatar
Default Re: How to install extended wheel studs (THCk20eg)
had some Skunk studs spin on me before.
Old Jun 30, 2005 | 03:30 PM
THCk20eg's Avatar
yeah i heard alot about skunk studs. cant go wrong with the arps. roll with us to fontana bro.
Old Jun 30, 2005 | 05:51 PM
hondaguyef's Avatar
Here's an Excellent write up: Click Here
Phil
Old Jul 1, 2005 | 08:38 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: How to install extended wheel studs (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Here's an Excellent write up: Click Here
Phil</TD></TR></TABLE>
WOW! That really is a good writeup!
Old Jul 1, 2005 | 08:50 AM
1fastVX's Avatar
Default Re: How to install extended wheel studs (Clayton)
Here is another post with instructions also. On the first set of instructions with the slide hammer I would have not re-used that bearing. I replaced mine with new Honda one since the race pulled out of the bearing like in his pictures.
https://honda-tech.com/zerothread?id=720159
John
Old Jul 1, 2005 | 04:44 PM
NAturalDC2's Avatar
Default Re: How to install extended wheel studs (1fastVX)
just curious but why do the skunk2 studs suck? and also ive heard tack welding is only required if youre pushing a **** load of power i think the person i talked to told me about 400+ or something, but why?
elitezdc5
Honda Civic (2001 - 2005)
Jul 1, 2008 05:17 PM
Flux
Dec 27, 2006 01:33 PM
RTW DC2R
Feb 13, 2006 08:21 PM
HotRodEG6
May 11, 2004 10:32 AM
zRd#1
May 14, 2003 11:46 PM
