Getting code 7 and 43 TPS and Fuel Supply System/ Something Rattaling on pass rear
95 ex coupe, getting 7 -throttle position sensor and 43-fuel supply system. Its weird, sometimes i get it when its raining or cold, i can turn the car off and start it again and it doesn't give me check engine light. Hasn't done it recently its been really hot. Wonder if the weather has anything to do with it.. has anyone else had this problem and if so what was the real issue. Any info, diagrams of the sensor would be great Thinking maybe the sensor is loose.
And one other problem, not sure if its the exhaust or rear alignment. If i let off first with not enuff gas the car gets a lil jumpy, sounds like something is loose, rattaling...or it could be just the exhaust? Sounds like it is right before the pass rear strut, and i can hear it right in the back seat on the pass side. Anyone have similiar probs?? and the car drives perfect so i'm thinkin its not the rear alignment...hopin the prob is just the exhuast is loose...
rickytz7111
Feb 17, 2007 04:39 PM
