Code 65, rear o2 sensor
Old Oct 3, 2011 | 01:16 PM
rayo53's Avatar
Default Code 65, rear o2 sensor
Tried searching, and couldn't find anything. Yesterday, took the cat out and the wire came with it, so it ripped. Turned the car on after and the CEL came on so I knew what it was, and so I'm asking, is it alright to drive with the rear 02 sensor out?
I know that the front one checks what the exhaust is like and the back checks to see if the cat's doing its job, but I've searched on Google and people have said before that the car might run better, any suggestions/help?
Old Oct 3, 2011 | 01:47 PM
GhostAccord's Avatar
Default Re: Code 65, rear o2 sensor
Will it run...yes. Will it run better, not better than if all your PGM-FI related parts were operating correctly.
Old Oct 3, 2011 | 01:57 PM
rayo53's Avatar
Not meaning to sound dumb if I am, but I don't think it has PGM-FI because another kid from my school has an older Accord but it says PFI on it.
Old Oct 3, 2011 | 02:16 PM
Yes your 97 Accord has Programmed (PGM) Fuel Injection (FI). It uses what is known as a sequential multiport fuel injection system. It has 1 injector for each cylinder (multiport) Each injector is opened individually via the engine control unit (ECU/EMU) to squirt only when required (sequential).
They stopped printing PGM-FI on the tops of the Accord intake manifold when they switched to the F22B1 & 2 engines in 1994.
Old Oct 3, 2011 | 04:15 PM
rayo53's Avatar
Alrighty. So as long as everything else works, then there won't be a problem with the sensor?
Old Oct 4, 2011 | 05:17 AM
StreetsideStig's Avatar
Correct me if I'm wrong, Ghost, but won't it go into limp mode? If so, you'll get terrible gas mileage and it's really hard on your other O2 sensor.
Old Oct 4, 2011 | 06:05 AM
Not limp mode. It will go into back-up mode. In this mode the CEL is on and the ECU will ignore the defective sensor and use a programmed set of values for it.
It is always better to fix any PGM-FI related issues like this. Running a car with the CEL on is never an optimal way to go. However, I have seen cars run for years without issue having the CEL on for secondary O2 sensor BS.
Old Oct 5, 2011 | 05:30 AM
Cool! I never knew that.
foumer
Honda Accord (2013 - 2015)
15
Nov 30, 2017 02:59 AM
PsXtreme
Oct 25, 2015 04:58 PM
5lugcivic
Jul 5, 2006 07:46 AM
tree guy
Nov 15, 2001 07:28 PM
