RC injectors: Which O rings to use(SEARCH motor is down)
Old Jun 15, 2005 | 04:53 AM
SupaFly_Honda's Avatar
Default RC injectors: Which O rings to use(SEARCH motor is down)
I bought some used rc injectors and they didn't come with the O rings to fit the injectors into the intake manifold. Can I modify my stock O rings to make them fit? Or can I use other rings from a different car to make them fit?
Old Jun 15, 2005 | 05:51 AM
IN VTEC's Avatar
Default Re: RC injectors: Which O rings to use(SEARCH motor is down) (SupaFly_Honda)
I always just modify the stock ones. Give RC Engineering a call and ask about the tapered injector grommets. I've used those before, but I'm not exactly sure where they came from b/c I bought the set slightly used.
Old Jun 15, 2005 | 06:00 AM
Default Re: RC injectors: Which O rings to use(SEARCH motor is down) (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I always just modify the stock ones. Give RC Engineering a call and ask about the tapered injector grommets. I've used those before, but I'm not exactly sure where they came from b/c I bought the set slightly used.</TD></TR></TABLE>
how did you modify yours?
Old Jun 15, 2005 | 06:12 AM
IN VTEC's Avatar
Dremel and a 120 grit cartridge roll on the inside of the grommet until it fits snugly. You need a snug fit or it'll have a vacuum leak.
dc2_build
Nov 9, 2014 10:50 PM
Seminole
Dec 17, 2007 09:43 PM
Ninja Mike
Sep 2, 2006 12:53 PM
JDM_Ej
Aug 8, 2005 01:56 PM
dustin
Feb 10, 2002 09:49 PM
