RC Injector Help
Old Dec 16, 2007 | 06:20 PM
Seminole's Avatar
Default RC Injector Help
OK so anyone know anything about this? I have RC SL9-310 Injectors for a Honda/Acura B Series engine. These are the 310 injectors and well they arn't fitting into the little rings (can't think of name right now. My brain is fried). It's weird cuz the stock ones fit perfect. Just wondering if the RC ones are supposed to sit up a little higher. The RC injectors just don't go in as far as the stock ones do. Like I said, I'm not sure if they are supposed to or not so some insight would be great. They came with no instructions. My next step is to call RC.
Thanks.
Old Dec 16, 2007 | 07:01 PM
bschulz's Avatar
Your seller did not give you the seal rings to go with them. You will have to dremel/drill your stock seals or order the proper ones.
Old Dec 16, 2007 | 07:10 PM
Seminole's Avatar
Default Re: (bschulz)
It came with the seals. Hmm I'll call JHP and ask him. Thanks...any other suggsetions? Like the injectors WILL fit but thy just sit up higher than the stock one...I dunno if they're supposed to though like I said. When you look and compair injector tips the RC ones are bigger at one point.
Modified by Seminole at 11:21 PM 12/16/2007
Old Dec 17, 2007 | 01:27 AM
Seminole's Avatar
Default Re: (Seminole)
up...anyone else???
Old Dec 17, 2007 | 05:15 AM
Seminole's Avatar
Help please anyone else.
Old Dec 17, 2007 | 07:26 AM
roachsboosted16's Avatar
Default Re: RC Injector Help (Seminole)
when i put in my dsm injectors they sat higher, but i just evenlu torqued them down with the injector rail mounts, i wuoldnt recomend this for anyone but its working for me.
Old Dec 17, 2007 | 09:57 AM
Seminole's Avatar
Default Re: RC Injector Help (roachsboosted16)
thanks. I just got a hold of RC and they said they arn't supposed to sit all the way down like the stock injectors because of the triple shot on the fuel compaired to the single of the stock injectors.
Thanks for the help
Old Dec 17, 2007 | 09:43 PM
bschulz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seminole &raquo;</TD></TR><TR><TD CLASS="quote">These are the 310 injectors and well they arn't fitting into the little rings (can't think of name right now. My brain is fried). It's weird cuz the stock ones fit perfect.</TD></TR></TABLE>
I thought you were referring to the stock injectors fitting perfectly into the seals. Sorry for the useless help.
Powered By Garrett
Jun 21, 2008 03:10 PM
B16Drag
Jun 9, 2004 09:18 AM
phiberoptik
Feb 10, 2004 06:41 AM
shadowdawn
Aug 13, 2002 03:03 PM
SpeedMonkeyRacing
Apr 25, 2002 10:15 AM
