d16a6 & d16z6 stock rev limit - I think I got it please confirm - mini me
ummm not sure exactly what the rev limiter is set at. i do know that anything past 7200 rpms doesnt make any power and its not safe. the hightest i got on that exact same set up is about 7300-7400 when i shift. and there i break tires losse and chirp.
Thanks, I am new to d series - just looking for a safe stock limit.
I am still curious as to what the limiters are at. And also a y7 - I know that should probably be in the ek forum but who says we can't swap those in our efs
To be safe, I would stick with the A6's rev-limit. You don't want to push it with that extra couple hundred rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">To be safe, I would stick with the A6's rev-limit. You don't want to push it with that extra couple hundred rpms.</TD></TR></TABLE>
What if I had pg6 rods with arp hardware?
Edit: I am not trying to ricer rev the **** out of the thing just want to get max power safely - like factory max power of the z6 head. So about 7400 then?
a stock a6 makes power to about 6800rpm an the Z6 makes it to about 7100rpm, just leave the stock 7413rpm limiter
i used to rev my d15z6 to 7800 and it never dropped a rod or bent a valve or anythin. usually id jsut shift at 7500
(the pistons melted from too much boost and not enough fuel)
I have the stock block/head for my Z6 and the rev limiter is 7600.....rule of thumb for honda motors...add 400 rpm to the redline and there ya go.
I wanna get an A6 block so I can mini me just like you with the Z6 head. Any ideas of where to find an A6 shortblock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoolJimWhy »</TD></TR><TR><TD CLASS="quote">I have the stock block/head for my Z6 and the rev limiter is 7600.....rule of thumb for honda motors...add 400 rpm to the redline and there ya go.
I wanna get an A6 block so I can mini me just like you with the Z6 head. Any ideas of where to find an A6 shortblock?</TD></TR></TABLE>
I might be able to find one for you but I am far away. I have no problem shipping it to you if you pay for it.
But if I were you I would look around locally. D series blocks are not exactly a rarity
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX »</TD></TR><TR><TD CLASS="quote">i used to rev my d15z6 to 7800 and it never dropped a rod or bent a valve or anythin. usually id jsut shift at 7500
(the pistons melted from too much boost and not enough fuel)</TD></TR></TABLE>
so you had a built block?
It's a fun set-up. I have a D16A bottom-end, which is the JDM VTEC-E, matched to a Z6 head. Most people said it wouldn't be too fast because of the bottom end - but I like it. Don't have any times yet though.
Anyway...just post a WTB in the classifieds and I'm sure someone swappin in a B-series or something would close to give away the A6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">
so you had a built block?</TD></TR></TABLE>
no it wasnt built. stock d15 block witha stock z6 head. + a jrsc strapped to it all. stock fuel system with the pos jackson racing fpr.
Might want to start a new thread and include detail for your questions.
not sure what you are trying to ask exactly.
dohdoh420
15
Sep 17, 2005 09:12 AM
SohcVtecCrix
Nov 19, 2002 01:12 PM
